Bank 1 vs. Bank 2 o2 sensor location - JeepForum.com
post #1 of 17 Old 09-11-2009, 08:02 AM Thread Starter
rvsmith88
What is the location of #1 Cylinder on a 2004 4.0l. Is it the drivers side or the passenger side of the engine. I have a o2 sensor code Bank 1 sensor #2.
rvsmith88 is offline
post #2 of 17 Old 09-11-2009, 08:45 AM
Alexia
Alexia's Avatar
Experimental Insanity! - Oxygen Sensor Resource
Downstream, Front Manifold - Bank One, Sensor Two
ODBII Codes: P0136, P0137, P0138, P0139, P0140, P0141, P0143, P0144, P0145, P0146, P0147
Physically located towards the front of the vehicle after the mini-catalytic converter.
2004 Jeep Wrangler Unlimited, Automatic
RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers -
Power Door Locks with Keyless Entry
Alexia is offline
post #3 of 17 Old 09-11-2009, 09:04 AM Thread Starter
rvsmith88
Bank 1
Which side of the engine/exhaust is bank 1. Driver's side or passenger's side. The code is P0 138.
post #4 of 17 Old 09-11-2009, 09:33 AM
Alexia
Alexia's Avatar
Both banks are located on the driver's side. Bank one is towards the front of the engine.
Alexia is offline
post #5 of 17 Old 10-30-2010, 07:55 AM
armartel
does anyone have any pictures of the o2 sensors? I searched through the forum, but couldn't find anything.
armartel is offline
post #6 of 17 Old 12-01-2010, 11:12 AM
jakesteel1
That would be helpful. I have a 2006 Rubicon with code P0137 indicating Downstream, Front Manifold - Bank One, Sensor Two; Physically located towards the front of the vehicle after the mini-catalytic converter.
Pictures would be helpful as I am unsure where to look. TY.
jakesteel1 is offline
post #7 of 17 Old 12-01-2010, 12:35 PM
NotURMailman
NotURMailman's Avatar
Follow the exhaust down from the #1 cylinder at the cylinder head. #1,2,and 3 will come together into one pipe. Follow that pipe down through the "mini" catalytic converter. The first sensor that you come to after that converter is the one you're looking for.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #8 of 17 Old 12-01-2010, 12:38 PM
biffgnar
biffgnar's Avatar
Just open the hood and take a look. Pretty hard to miss. Picture is not going to show you anymore than what you will see when you take a look. Not real confusing.
biffgnar is online now
post #9 of 17 Old 12-01-2010, 01:12 PM
chris142
You better open your hood and look. You don't have a V6 you have an inline 6. The cyls are numbered 123456 from front to rear.
Bank 1 is fed by cyls 1,2and 3 and sensor 2 is after the cat in #1 bank.
chris142 is offline
post #10 of 17 Old 12-01-2010, 02:58 PM
jakesteel1
While this explanation helps to clarify, I took some pics.
I am looking for: P0137 indicating Downstream, Front Manifold - Bank One, Sensor Two; Physically located towards the front of the vehicle after the mini-catalytic converter.
These two were the furthest away, the one on the left being towards the front.
Then there were these 2 closer to the bottom of the Jeep. This one being closer to the front:
This one being closer to the rear:
post #11 of 17 Old 12-01-2010, 08:37 PM
LJameson
The one on the left is bank 1, on the right is bank 2. Both upstream.
Bank 1 downstream
Bank 2 downstream. Hope that helps.
PS. I'm so glad I don't live in a salt infested area. Wow.
1990 YJ
LJameson is offline
post #12 of 17 Old 12-01-2010, 10:45 PM
RogueSpear2023
This is the one you want to remove that is causing your problems.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #13 of 17 Old 05-04-2012, 01:34 PM
04ollllloguy
ok so...i realize the factory manual uses the designations 1/1, 2/1,1/2,2/2 for the O2 sensors, however, the parts store only labels the sensors as front upstream, rear upstream, front downstream, rear downstream. am i correct in assuming that 1/1 is F/U, 2/1 R/U, 1/2 R/U, 2/2 R/D?
04ollllloguy is offline
post #14 of 17 Old 05-04-2012, 01:36 PM
biffgnar
biffgnar's Avatar
Originally Posted by 04ollllloguy View Post
ok so...i realize the factory manual uses the designations 1/1, 2/1,1/2,2/2 for the O2 sensors, however, the parts store only labels the sensors as front upstream, rear upstream, front downstream, rear downstream. am i correct in assuming that 1/1 is F/U, 2/1 R/U, 1/2 F/D, 2/2 R/D?
Fixed it for you.
post #15 of 17 Old 05-04-2012, 01:38 PM
04ollllloguy
ha ha thnx
BANK 1 SENSOR 1 and BANK 2 catalyst below thresh 04<TJ>renegade TJ Wrangler Technical Forum 22 12-31-2016 06:39 AM
chasing down bank 1 sensor 1 o2 loaderopp TJ Wrangler Technical Forum 9 01-01-2010 07:33 PM
P0153 Bank 2 Sensor 1??? Bertha TJ Wrangler Technical Forum 14 11-10-2009 06:11 PM
2002 I6, O2 Bank 1 Sensor 2 rossb TJ Wrangler Technical Forum 1 04-27-2008 10:47 PM
GGRRR- Bank 2 Sensor 1 ***** Bertha TJ Wrangler Technical Forum 0 03-21-2008 08:40 PM
