BANK 1 SENSOR 1 and BANK 2 catalyst below thresh - JeepForum.com
post #1 of 23 Old 02-08-2009, 08:50 PM Thread Starter
04<TJ>renegade
Need to know which oxygen sensor is bank 1 sensor 1 and which cat is bank 2...its a 2004 4.0L
SOLD 04 TJ X "Renegade": 8.8 rear HP30 front 3 link/4 link snorkel 35" km2s
98 TJ 4 Banger STOCK getting a 5.2 Magnum and starting over
04<TJ>renegade is offline
post #2 of 23 Old 02-09-2009, 12:37 AM
Marholmes44
Normally your bank one is right after the exhaust manifold and the bank 2 will be right after your cat but you should be able to ask someone at auto zone or advance to comfirm for sure.
Marholmes44 is offline
post #3 of 23 Old 02-09-2009, 12:43 AM
JHenry
what code is showing....?
JHenry is offline
post #4 of 23 Old 02-09-2009, 08:35 AM
Slithering_Joe
Bank #1 is always the group of cylinders on the side of the engine where the manufacturer designates where cylinder #1 is located. Some manufactures of inline engines may designate multiple banks. In the case of late model inline-6 Jeep engines, bank #1 contains cylinders 1-2-3, and bank #2 is 4-5-6. Cylinder #1 is located at the front or accessory/pully side of the engine for a Jeep.
In this context, "Sensor 1" is located upstream or before of the catalytic converter. "Sensor 2" is located downstream or after the catalytic converter. The PCM will compare the reading of O2 Sensor 2 to the reading of O2 Sensor 1 of the same bank to determine if the catalytic converter is working properly.
What code(s) are you getting?
4.0L TJ
Slithering_Joe is offline
post #5 of 23 Old 02-09-2009, 09:36 AM
jinx44
Absolutely correct.
As he said, which code are you throwing? P0430? That should be bank 2 catalyst.
Rusty's 5.5" lift, Sniperfab armor, PSC fenders, RR steering, Riddler diff cover, Teraflex Bellyup
8.8 rear spooled, HP 30 front ARB, 4.56s, Tera 2Lo kit, AA SYE
Fabtech front bumper, smitty rear/carrier, Smitty XRC8 winch, MM wireless control
35X12.50 Xterrains
jinx44 is offline
post #6 of 23 Old 02-09-2009, 10:21 AM
Slithering_Joe
Cylinder numbering varies from manufacturer to manufacturer.
| pulleys side | ------ | flywheel side |
Cylinder Numbering:
GM, Jeep V8:
2-4-6-8
1-3-5-7
Ford V8:
1-2-3-4
5-6-7-8
Jeep Inline-6
1-2-3-4-5-6
Jeep V6:
2-4-6
1-3-5
4.0L TJ
post #7 of 23 Old 02-09-2009, 11:27 AM Thread Starter
04<TJ>renegade
I've got a P0135 and a P0432 codes. Any idea if its just the 02 sensor is does this mean the cat is gone to? I couldn't see how is cat is gone at 50k that seems premature.
post #8 of 23 Old 02-09-2009, 11:47 AM
timmytimm3
I had a po432 code for a few days but had gone away? Is the 02 sensor starting to go? Should I just replace both of them?
Thanks
timmytimm3 is offline
post #9 of 23 Old 02-10-2009, 02:19 PM Thread Starter
04<TJ>renegade
Thanks
thats exactly wut mine did and now its back with 2 codes
post #10 of 23 Old 02-10-2009, 06:46 PM
chorndawg
Similar situation here....P2096.....already replaced the downstream O2 and the code came back after 45 miles.
chorndawg is offline
post #11 of 23 Old 07-13-2009, 10:07 AM
sbninja
sbninja's Avatar
Tag for update?
2004 Jeep Wrangler Sport - Black
WARN steering box skid,Nth degree Oil pan skid
RE 3.5" - M.O.R.E. 1" BL - M.O.R.E. 1" MML
15x8 Tech1 Rock Crawlers (4.5" BS)
35"x12.50x15 Dunlop Radial Mud Rovers
Aussie locked 30/ Ultimate 35 kit w/detroit
Black Jeep Club v2.0 Member #49
sbninja is offline
post #12 of 23 Old 07-13-2009, 02:05 PM
97TJSoldier
hey little heads up when you guys are replacing these o2 sensors.....i ran into an issue where the scanner was saying that my upstream sensor (after the manifold) was "stuck on rich"....well i changed it and the problem never went away the jeep was running rich and it was the down stream sensor (at the catalyst) that was reading wrong saying that it was running fine when it was actually running rich.....other than that make sure your air filter is clean and the throttle body is clean....that sometimes will kick on the o2 sensor intermittently
97TJSoldier is offline
post #13 of 23 Old 07-15-2009, 09:03 PM
Crassshett
My 2003 jeep Liberty has a code P0153 coming up. It states bank 2 where in the world is that at? Please help...
Crassshett is offline
post #14 of 23 Old 07-15-2009, 10:39 PM
cj847
A code is simply a code. It does not mean a certain component is bad (for example O2 sensor). It simply says a parameter is out of spec. Study what possible problems can throw a code before randomly replacing parts. Most codes have several possible causes.
http://www.obd-codes.com/trouble_codes/
If you are going to do a lot of this kind of work, invest in a code SCANNER, not a code reader. Scanners can retrieve freeze frame data, live data and test O2 sensors.
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline
post #15 of 23 Old 05-09-2010, 04:46 PM
Nagy34
Ok my engine light has been on for a very long time. I drive a 2003 TJ Wrangler 4.0. I knew the code was just an 02 sensor error code. Finally I am getting tired of the horrible fule milage and want this fixed. I did a little research and replaced a sensor (possibly the wrong one a month ago). After the sensor replacement there was no change in the error code, even after clearing the previous code a few times. The error code I am getting still presists. I am still fairly sure its a sensor that's giving this problem however, not 100% sure.
The scanner read out is as follows...
P0138
02 Curcuit High Voltage (Bank1, Sensor 2)
Freeze Frame Data
Fuel Sys 1 CL
Fuel Sys 2 CL
Calc Load (%) 21.18
ECT (c) 84
STFT B1(%) 0.00
LTFT B1(%) 0.00
STFT B2(%) 3.13
LTFT B2(%) 0.00
MAP (kPa) 70.00
Eng RPM 1600
Veh Speed Km/h 59
I really need to figure out what exact sensor Bank1 sensor2 is. More importantly where it is. Will simply replacing the sensor fix the problem or do i have other issues? Please have a look at this picture, and I even took a quick video. The picture is of the sensor I believe I need to replace.
http://home.cogeco.ca/~jeffnagy/Car/058.JPG
http://home.cogeco.ca/~jeffnagy/Car/Jeep.mov
Nagy34 is offline
Check engine light: P2098 Post Catalyst Fuel Trim System Too Lean Bank 2 jstn TJ Wrangler Technical Forum 15 03-04-2017 12:11 PM
Bank 1 vs. Bank 2 o2 sensor location rvsmith88 TJ Wrangler Technical Forum 16 01-28-2013 04:31 PM
Intermittent P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2) Zen TJ Wrangler Technical Forum 2 12-21-2009 05:27 PM
P0432 Catalyst System Low Efficiency Bank 2 SpaceWrangler TJ Wrangler Technical Forum 38 10-21-2008 09:01 PM
ODBII Code P0432 - Main Catalyst Efficiency Below Threshold (Bank 2) mhc TJ Wrangler Technical Forum 5 04-13-2006 04:57 PM
