Ball joints - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Ball joints
Savvy Billet LED Tail LightsRough Country Jeep Suspension Deals at Rockridge 4WD!Alloy usa heavy duty ball joint kits
Unread 11-15-2014, 03:23 PM   #1
Rican142
Ball joints
How do I go about figuring out what kind of ball joints I need? I see how they have the centered ones and they have off set ones?
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline   Reply With Quote Quick reply to this message
Unread 11-15-2014, 03:26 PM   #2
rda616
You don't need offset unless your housing is bent. New spicer balljoints are about $40. Per side on Amazon.
rda616 is offline   Reply With Quote Quick reply to this message
Unread 11-15-2014, 03:57 PM   #3
Rican142
How do I go about checking the housing?
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Unread 11-15-2014, 05:05 PM   #4
BYuen
Take your Jeep to an alignment shop unless it is obvious enough to tell by looking at the housing or looking down the tubes. Did you do something to suspect you bent the housing? You'd have to jump the Jeep or hit something pretty hard.
BYuen is offline   Reply With Quote Quick reply to this message
Unread 11-15-2014, 09:03 PM   #5
Rican142
No, theirs no reason forgetting bent
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Unread 11-15-2014, 09:38 PM   #6
GringoLoco
Yeah, just get the regular ball joints. Get Spicer though, they seem to be the best for OE type replacement.
YELLOW Jeep Club Member #5606
13 mpg - edit: 12 mpg
No hi-lift on the hood (yet)
Odd noises
Still can't get it to take off from a treadmill....
GringoLoco is offline   Reply With Quote Quick reply to this message
