Ball Joints - JeepForum.com
post #1 of 9 Old 05-08-2012, 01:35 PM Thread Starter
Scala37
Ball Joints
This may seem like a stupid question but can the upper ball joints simply be tightened rather than replaced all together? Theres a good amount of separation between the ball joints and the U joint compared to my buddies jeep so im thinking theyre just loose.
Jeep
Scala37 is offline
post #2 of 9 Old 05-08-2012, 01:38 PM
biffgnar
biffgnar's Avatar
If your ball joints are loose, then yes they should be tightened. Is that a substitute for replacing them if they are worn out, no.
Romney in 2020!
biffgnar is online now
post #3 of 9 Old 05-08-2012, 02:06 PM Thread Starter
Scala37
I understand if they are wore they should be replaced. Im going to have a friend of mine determine if they should be replaced or if tightening them is all they need. They dont look worn but ill check to be certain.
Jeep
Scala37 is offline
post #4 of 9 Old 05-08-2012, 02:33 PM
dcope17
What does a worn ball joint look like? I need to go have a look at mine.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #5 of 9 Old 05-08-2012, 02:39 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Bad ball joints look like this:
and for reference, worn u-joints looks like this:
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 9 Old 05-08-2012, 03:11 PM
srlbotanical
I've never experienced a ball-joint that needs to be re-tightened. They have a tapered shaft and once they are installed, you put a cotter pin through the castle nut and nothing should move or loosen. If you are seeing any movement, the b-joint is bad.
Great reference video's above!
Two Trackers 4WD Club
Wheeling in West Michigan for over 35 years.
HIGHER POWERED!!
srlbotanical is offline
post #7 of 9 Old 05-09-2012, 07:31 AM Thread Starter
Scala37
i just jacked up my jeep and shimmied the tires up and down using a pry bar and i saw NO play in the upper or lower ball joints. However, there is about a 3 millimeter gap between the ball joint bushing and the socket it goes into
Jeep
Scala37 is offline
post #8 of 9 Old 05-10-2012, 06:58 AM
srlbotanical
At this point, your best bet is to post a picture or two.
HIGHER POWERED!!
post #9 of 9 Old 05-10-2012, 07:40 AM
andy02
I think he is trying to say that he has a 3 MM gap between the knuckle and the C?
Originally Posted by Hendrix
September 11 2001
Never Forget!
andy02 is offline
ball joints , death wobble , universal joint
Ball Joints mc2065 JK Wrangler Technical Forum 17 06-07-2011 07:53 PM
Ball Joints Gone Bad? luk4mud TJ Wrangler Technical Forum 4 02-24-2009 03:51 PM
ball joints BCJEEP TJ Wrangler Technical Forum 1 10-14-2006 09:46 AM
Axle u-joints & maybe ball joints. CityJeep90 YJ Wrangler Technical Forum 2 06-04-2006 05:23 PM
Help with front end work... ball joints, u-joints kaffeene YJ Wrangler Technical Forum 5 04-27-2005 08:45 PM
