Badlands 9,000 LB Harbor Freight winch - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Badlands 9,000 LB Harbor Freight winch
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shippRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 11-01-2013, 01:03 PM   #1
CPFLIP
Hey guys i read some pretty decent reviews on the harbor freight badlands winch, so i picked one up... 150 bucks after my employee discount! not bad! but i hate the steel cable and i want to upgrade to a synthetic winch line! how do i know how long i could go or how thick of rope i should go? and your supposted to run a hawse fair-lead on synthetic line instead of roller correct?
CPFLIP is offline   Reply With Quote Quick reply to this message
Unread 11-01-2013, 01:18 PM   #2
-jb-
get a fair lead. 3/8 synthetic 100ft. This is usually the norm for a 8k, 10k winch
Yellow Jeep Member #42
01 TJ Sport
00 TJ Sport
-jb- is offline   Reply With Quote Quick reply to this message
Unread 11-01-2013, 01:33 PM   #3
Jerry Bransford
Administrator
Jerry Bransford's Avatar
How much 5/16" wire rope came with it? 3/8" synthetic is what you want but the winch won't hold as much of that as it does its 5/16".
A roller fairlead is better for and easier on synthetic rope than a hawse is. The initial rumors that a hawse was required for synthetic ropes were quickly found to be false. I went back to my roller fairlead years ago.
Thor at www.winchline.com is an excellent experienced source for synthetic ropes. And a Jeeper too.
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread 11-01-2013, 01:36 PM   #4
rchase559
Not all roller fair leads are the same. You can run a roller as long as it is one where the rope cannot get pinched in the corners and it is smooth and free of any burrs.
The amount of line is dependent on the specific winch model. It will vary from one manufacturer to the next. What size and length line does this winch come with?
rchase559 is offline   Reply With Quote Quick reply to this message
Unread 11-01-2013, 01:41 PM   #5
Jerry Bransford
Administrator
Can you show any major brand of roller fairlead used on winches we install onto our Jeeps where that can happen? I don’t believe you can show one where rope getting caught in the corners could really (realistically) happen.
Edit: It appears you slightly softened your comments on roller fairleads after I replied.
Getting Savvy...
Unread 11-01-2013, 01:48 PM   #6
CPFLIP
i have 50 foot 5/16 i believe i have a pic of the winch and bumper as me profile pic
Unread 11-01-2013, 01:53 PM   #7
Jerry Bransford
Administrator
Double check that length, only 50' of wire rope is not common for a new 9,000 lb. capacity winch.
Getting Savvy...
Unread 11-01-2013, 02:01 PM   #8
rchase559
I've had my hands on fairleads that were different than the one that came with my Warn. The rollers did not overlap enough IMO, especially if one is careless when setting up for a pull.
No I do not have any pictures. What I can tell you is that the line CAN get caught and damaged in some roller fairleads.
With that said, educating oneself on proper recovery techniques and having the ability of recognizing and minimizing possible issues is just as important as the equipment you use. I've seen some very poor recover practices by people who didn't know any better.
Unread 11-01-2013, 02:06 PM   #9
dayriesw
dayriesw's Avatar
So you bought a $150 winch and you want to put a $250+ syn. line on it?
Two jeeps, neither like to work.
dayriesw is offline   Reply With Quote Quick reply to this message
Unread 11-01-2013, 03:32 PM   #10
Jerry Bransford
Administrator
He can always move that $250 synthetic line to a better quality winch later when it's time to replace that Badlands winch.
Getting Savvy...
Unread 11-01-2013, 03:44 PM   #11
Timmay82
Yep I am an unemployed college student (The VA pays me very little) but the common sense route is it's better to have a budget winch, than none at all. But with 400 dollars could he have bought a better Chinese winch?
Disclaimer: All opinions expressed, (or even assumed) under the JeepForum user name: Timmay82, are strictly that of somebody else. If you don't agree, feel that you have been attacked and as such your feelings are hurt by the above said user, than you may present any issues that you may or may not have with somebody else!
Timmay82 is offline   Reply With Quote Quick reply to this message
Unread 11-01-2013, 04:14 PM   #12
saint_louligan
That's what I paid for my Warn M8000 new about 3 years ago. Granted it was a great deal - I haven't seen them anywhere near that price except back then.
If you're on a budget, why go synthetic at all? I haven't replaced the wire rope with synthetic yet and probably won't. I only installed it (the winch) as cheap insurance and don't really use my current Jeep like I did older ones I've owned.
saint_louligan is offline   Reply With Quote Quick reply to this message
Unread 11-01-2013, 04:19 PM   #13
Timmay82
Yep. That is my train of thought. I am assuming he bought it because of an existing budget. And if that is the case steel cable has worked for decades.
Unread 11-01-2013, 04:31 PM   #14
-jb-
Maybe he only needs the winch on that one time he may be in a bad spot because he doesn't wheel a lot. Not everyone needs an expensive winch or a used one. Now if he is using it a lot then let the typical arguments fly.
Just answer the guys questions and lay off the winch brand.
01 TJ Sport
00 TJ Sport
Unread 11-01-2013, 07:00 PM   #15
rikkards
rikkards's Avatar
I bought my XD9000i for $360 plus shipping. It is a very early model and I bought it used. I am still running the steel cable that it came with. Once the cable needs to be replaced I will look at synthetic. I use it maybe once or twice a year and it is never too serious of a pull
Machete don't tweet
- Machete
rikkards is offline   Reply With Quote Quick reply to this message
winch accessories
