Is it a bad thing to drive in 4 wheel drive
| Spartan Lockers FREE SHIPPING Excellent Prices | Free Shipping on TIRES at KrawlOff-Road | Black Magic Brakes - 5% Off, No Minimum Purchase Required |
#1 | |
If you don't actually need to? My SO said he remembered hearing somewhere that you shouldn't engage the 4 wheel drive unless you were actually slipping and needed it.
I like to engage it if I'm on rough, potholey, dirtroad in case I need it. Is that a bad thing? thanks!
2004 TJ Sport 4.0L, 5 Speed, D44, Raingler Rack and a Half + Side Nets :) Shale Green like licorice "Crows", she looks black, but she's really green |
#2 |
as long as your wheels are on a surface that will allow slipping then you won't damage anything. Driving around on pavement in 4wd is stupid. Off road is alright but why would you "need" it?
#3 | |
Mr.Clifford is right...wait until the slipping occurs. Have fun and be safe.
[B]|2000[COLOR=sienna] Amber Fire [/COLOR]TJ Sport|[/B] -[B][SIZE=1]4.0L I-6[/SIZE][/B] [SIZE=1]|5spd Manual|[/SIZE] -[B][SIZE=1]3.73 Dana 44 [/SIZE] [/B] [SIZE=1]|rear|[/SIZE] - [B][SIZE=1]3.73 Dana 30[/SIZE][/B] [SIZE=1]|front|[/SIZE] -[B][SIZE=1]3.5" Superlift suspension[/SIZE][/B] - [B][SIZE=1]1" Body Lift[/SIZE][/B] -[B][SIZE=1]32" BFG All-Terrain[/SIZE][/B] [B] [COLOR=sienna][SIZE=1]Chrome parts for sell [Chrome Side Bars | Chrome Grille Inserts | Chrome Sway Bar Cover] PM me if interested.[/SIZE][/COLOR] [/B] [B][url]www.redrock4x4.com[/url][/B] |
#4 |
Well, in the case of today, I was on a logging road that climbed a pretty high hill near my house....parts of the road were quite steep and the first time I encountered a steep part, my wheels slipped some. That's why I put it in 4 wheel for the rest of the climb, even though most of it was easily handled by two.
The logging roads are very cool here in the PNW when you're allowed access...they go way up into the mountains, often carved in the hillside with cliff like drop offs on the outside of the road... ![]()
#5 |
Putting it in 4wd when you are on a dirt road is fine the only time you shouldn't put in in 4 is on dry pavement, like it says above, as long as the tires can slip, its fine to put it in 4 and wont hurt a thing. I personally put in in 4 any time I think there is a chance of needing it, its better to be in 4 and not need it, then to get stuck in 2 and hope you can get out, when you have lost traction and your wheels are already spinning is NOT the time to put it 4 wheel drive....
Dacaur 99 WJ Laredo 2.5" Budget boost, 265/75/16 tires, K&N air filter www.dacaur.com/jeep.html Past Jeeps: 1992 YJ 4.0, 5 speed 6", lift 33's 1992 XJ 4.0, auto, 3" lift, 31's 1999 XJ 4.0, auto, 3" lift, 31's 1985 XJ 2.5, 5 speed, no lift, 255/70/15's --------------- |
#6 |
I'll unpimp your auto...
just a question related to this guys. Most of the 4 wheel drive vehicles I've been in have been all time 4x4. Why isn't a Jeep that way? (Besides the fact that the gas mileage is already bad enough?)
#7 |
Yeah bruddah,
the gears turn at slightly different rates so the occasional slip keeps you from tearing up your differential |
#8 | |
AWD and 4wd are diffeent things. AWD allows each wheel/axle to turn at different rates via some type of limited slip/clutch/viscious coupling device on the transfer case. They work fine for street and trail driving. A 4x4 system has a transfer case that locks the front and rear driveshafts together. 50% of the power going to each driveshaft. Ususaly the t-cases are stronger, and usualy will have a low range. There are other differences, but these are the basics. |
#9 | |
99 Jeep Wrangler Sport, 4.0 I6, 5-speed manual, Dana 44 rear, 3.73 gears, 4"(3.5") Procomp front, 4.5" RE rear, 33x12.5 BFG mudders on 15x10 black rockcrawlers, warn rockcrawler front bumper w/ warn 9500ti winch, warn rear rockcrawler w/ tire carrier, currie SYE, front Detroit locker |
#10 | |
If you jack up one side of your jeep with an open rear diff in 2wd and put it in gear the tire in the air will spin freely and the other won't move. Both tires are receiving equal torque. The torque isn't enough to make the wheel on the ground turn. Without motion, there is no power. So while both wheels are receiving equal torque only the jacked up wheel is being powered. |
#11 |
I understand what you are saying with regards to an axle. But the tcase.. isn't it driven by a chain? that is engaged and locked "fully" when the handle is pulled up?
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks. Subscribe to CRAWL |
#12 | |
Master of Reality
Chuck
Chuck Grissom Black Jeep Society Member My Jeep Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas A. Edison |
#13 | |
On an open diff, if you jack up the rear end in 2WD, and rotate one wheel the other wheel will want to spin the other way. This is because the average rotational speed of the two wheels must equal the speed of the drive shaft. Since the drive shaft isn't moving, +1 rpm (forward raotation) and -1 rpm (backward rotation) cancel out. AWD, 4wd part time, and 4wd full time systems are very differnt. Most AWD cars do have a differential between the fron and read drive shafts. Audis for instance have a torsen diff that changes the power delivered to the front/rear. Subaru's claim that 90% of the power goes to rear during takeoff, and 90% to front while deaccelerating.
Shadow Knight of clan S.D.S. Red '04 TJ Sport D30/D44 4.56 gears + f/r ARB york OBA RE 3.5 superflex + 33 MT/R's |
#14 |
All that being said, we still take our rigs out in 4WD and go through some seriuos tranfer case torture i.e. rock climbing and so on. Is the low speed of 4 wheeling having a lesser harmful affect than it would on regular driving speed.
2000 Black TJ Sport, FF14 bolt disk brakes Detroit and 5.13s, HP D60 ARB and 5.13s, TF727/Atlas 4.3, stretched 104" on 39" IROKS |
#15 | |
[QUOTE=Jeep89JV;9284099]Do I let others drive my rig? No -- Why, because if this ship sinks i'll be the captain and I go down with this ship.[/QUOTE] [url]http://www.jeepforum.com/forum/f12/motorcraft-carb-swap-961766/[/url] |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
