Bad shake at 55-60 mph - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Bad shake at 55-60 mph
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 09-04-2012, 10:56 AM   #1
clg82
BLUMPKIN
clg82's Avatar
Hey everyone took the jeep out of town this weekend, and when hitting the 55mph -60mph speeds i get bad vibrations......but below 55 and above 60 there is no vibrations...could this be driveline related? or tires need balancing? thanks for any help....~Chris
clg82 is offline   Reply With Quote
Unread 09-04-2012, 10:57 AM   #2
Robert J. yates
Could be anything... what have you changed recently?
Originally Posted by keith02 View Post
I'm a career submarine sailor who navigated the world blind excect for instruments.
Robert J. yates is offline   Reply With Quote
Unread 09-04-2012, 10:59 AM   #3
clg82
BLUMPKIN
clg82's Avatar
lower front control arms with savvy JJ adjustable control arms..
Unread 09-04-2012, 11:05 AM   #4
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Speed sensitive shimmies/vibrations felt through the steering wheel are nearly always tire or sometimes wheel related. Out of balance, out of round, bent wheel, etc. A bad alignment can cause tire problems that can cause a shimmy or vibration but by itself, a bad alignment will not cause a speed-sensitive shimmy or vibration.
Vibrations felt up through the seat of your pants are nearly always drivetrain related and often caused by a bad u-joint or bad pinion angle.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 09-04-2012, 11:18 AM   #5
clg82
BLUMPKIN
clg82's Avatar
I did feel it more in the seat of my pants than the steering wheel....would those certain speeds be because of drivetrail as well?
Unread 09-04-2012, 11:22 AM   #6
Jerry Bransford
Yes some vibes like from a bad u-joint can be speed sensitive. Pinion angle related vibrations are often noticed most when either accelerating or deaccelerating. Too high of a rear pinion angle will cause more vibrations when accelerating, too low of a rear pinion angle will cause more vibes when deaccelerating.
Getting Savvy...
Unread 09-04-2012, 11:27 AM   #7
clg82
BLUMPKIN
clg82's Avatar
I have all new ujoints in the rear driveshaft, and new ones in the tom woods up front......maybe a tire rotation is in order?!
Unread 09-04-2012, 11:32 AM   #8
Jerry Bransford
At this point, if you are sure your rear pinion angle is good, I'd try a different tire balancer or take it back and tell them to balance them again. The bigger the tire, the more critical it is that the tires be perfectly balanced. Many tire balance jocks only balance tires to what they feel is "good enough" which isn't usually good enough for a TJ. My local Discount Tire shop normally does a good job balancing my tires for me but I have had to come back twice in one day several times to have them balance the tires again when the first job left speed-sensitive shimmies.
Getting Savvy...
Unread 09-04-2012, 12:23 PM   #9
Robert J. yates
Are you sure you got the front pinion angle dialed in correctly with those new arms? Pinion angle takes precedence over caster on the front end.
Unread 09-04-2012, 01:07 PM   #10
clg82
BLUMPKIN
clg82's Avatar
How is the front pinion angle supposed to look in relationship to the yoke?
Unread 09-04-2012, 01:13 PM   #11
Hughes6
Same thing happened to my jeep and at the same speed as you said. I got my tires balanced and it was fine after that.
Hughes6 is offline   Reply With Quote
Unread 09-04-2012, 01:36 PM   #12
Robert J. yates
You set it up the same way as the rear..... rotate the front pinion until it is pointed at the t-case yoke. I'd shoot you a picture of mine but its a high pinion 30 and the way the driveshaft is set up, it looks a bit different. Maybe someone else here can post one up for you.
Unread 09-04-2012, 01:38 PM   #13
clg82
BLUMPKIN
clg82's Avatar
I should be able to figure it out...... might try and get the tires balanced first and see if that fixes things..
Unread 09-04-2012, 01:47 PM   #14
toolbate
My tj did that after i went mudding one time. It was just caked on mud inside the tires and rims
toolbate is offline   Reply With Quote
Unread 09-04-2012, 02:11 PM   #15
clg82
BLUMPKIN
clg82's Avatar
no mud anywhere on my jeep.....
