Bad KNOCK comin out of 4wd - JeepForum.com
post #1 of 8 Old 12-05-2004, 11:08 PM Thread Starter
JakeJones
After i'm comin out of 4wd and get back on the the road... it still feels like it's in 4hi and then about 500yards down the road KNOCK! and it's back in 2hi.
What's the deal?
i have a t-case drop with 3.5" lift
Yellow 00 Sport RE 3.5" 33 FirestoneM/Ts
JakeJones is offline
post #2 of 8 Old 12-06-2004, 08:00 AM
BumbleBeeTJ
BumbleBeeTJ's Avatar
same thing happens to me...i don't know why. so i can't do shift on fly which i probably need sometime this winter
2014 JKUR 6spd --> 2015 JKU AT
BumbleBeeTJ is offline
post #3 of 8 Old 12-06-2004, 08:38 AM
FlexyTJ
FlexyTJ's Avatar
This is normal (well I dunno about the loudness of it you seems to be describing), mine is more of a barely audible/discernable "tap". It takes a slight load to disengage the front outputshaft...mine shifts on the fly with no problem at any reasonable speed.
maybe you have a sloppy u-joint in the front D/S?
Same reason you need to drive the old Yota 4 runners in reverse a bit after disengaging the 4wd to actually get it to go back to 2
MK Motorsport & Fabrication
FlexyTJ is offline
post #4 of 8 Old 12-06-2004, 10:38 AM
BumbleBeeTJ
well it worked fine before and recently it sticks to 4hi. even when i put the lever down in 2hi. if i tried to put the lever back into 4hi, it won't go in cuz it's already STUCK there. and BIG CLUNK down the road whenim going like 50mph....
post #5 of 8 Old 12-06-2004, 03:34 PM Thread Starter
JakeJones
same exact way with mine
post #6 of 8 Old 12-06-2004, 04:05 PM
Stu Olson
Stu Olson's Avatar
The first and most simply check would be to ensure your fluid level in the t-case is correct.
While I don't have a t-case drop, could there be an issue it and the t-case shift linkage getting a little out of sorts and not fully shifting the mode fork from 4WD to 2WD? (4HI to 2HI)
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #7 of 8 Old 12-07-2004, 02:51 PM
RkSldr
RkSldr's Avatar
I had the same exact problem this past year. I couldn't shift into 4-HI other than very slow speeds. Then when I shifted back into 2 wheel drive, it would pause anywhere from 10 seconds to a minute, then a huge KLUNK. If I was on a trail, I could slow roll in reverse and shift into 2 wheel and it would shift without the klunk.
I know this won't help, but since I put in a SYE with the lift, it doesn't happen anymore, it shifts like new. Maybe something is slightly out of place in the transfer case. Couldn't tell you what was wrong.
2000 TJ, 4.0L, 5 speed
4.5" RE Extreme Duty Long-Arm
1" M.O.R.E. BL, 1" M.O.R.E. MML
Nth degree Mobility shock shifters
AA SYE/Tom Woods Shaft
33" Goodyear MTRs on 15x8 Cragar 352s
3.73 gears, D30/D35
2 PIAA 540 Driving Lights
4 IPF Lights
2 Stock Fog Lights
4 Rock Lights
Green Jeep Member #154
RkSldr is offline
post #8 of 8 Old 12-07-2004, 02:58 PM
BumbleBeeTJ
I changed the fluid and it started to happen so i changed it again. and I did put a 4" lift with 1" transfer case drop so that may have something to do with it.....
Knock, Knock whos there? chunks of piston DV8 TJ Wrangler Technical Forum 21 09-17-2009 08:53 AM
loud knock knock knock...noise when backing up shea666 TJ Wrangler Technical Forum 5 05-30-2009 01:10 PM
Wire comin from under seat??? Wrangler_91 TJ Wrangler Technical Forum 4 05-09-2009 11:59 PM
why is there water comin from under my dash? Git-R-Done YJ Wrangler Technical Forum 15 11-30-2006 10:38 PM
Its comin along SLOWLY... Stock88YJ YJ Wrangler Technical Forum 2 10-07-2003 10:15 PM
