bad gear sound - JeepForum.com
post #1 of 5 Old 02-09-2010, 07:25 AM Thread Starter
mcmopar
bad gear sound
I just got done putting gears and lockers in my Jeep, the tooth pattern looks good everything looks good. When I took it on a test drive I didn't even get it out of the driveway when I noticed that there was a grinding sound when I let off of the gas to shift or slow down. When accelerating it all sounds good. This is my first gear change so any thoughts on this problem would be helpful. I thought that it was coming from the front but when I took the cover off I did not see nothing that looked out of the ordinary.
cheap, fast, or reliable, pick 2
mcmopar is offline
post #2 of 5 Old 02-10-2010, 08:15 PM Thread Starter
mcmopar
nobody has ever heard of this before that has done gear swaps HELP
mcmopar is offline
post #3 of 5 Old 02-10-2010, 09:28 PM
kllrbee
How long has your jeep been sitting outside since the reagear?
To Alcohol!...The cause and solution to all of life's problems. - Homer
kllrbee is offline
post #4 of 5 Old 02-11-2010, 07:35 AM Thread Starter
mcmopar
I put the gear lube in then test drove it within the hour
mcmopar is offline
post #5 of 5 Old 02-11-2010, 08:31 AM
GroundAssault
GroundAssault's Avatar
When driving my jeep my after the gear swap, I too got a pretty strange sound. Basically it was high pitched and when I would lightly sit on the skinny pedal grinding would be added to the high pitched sound. I took it back to the guy and he said I had "burned the face off the gear". So I bought another gear set and install kit and he again installed the gears. I followed the recommended break in to the tee but again I got the same sound. I was told that the guy did not use a case spreader and follow proper spec on the Dana casing. I am not sure exactly what that means but my sound is only above 55-60. So I figure I will drive it till I blow the rear end up and either do a 8.8 or a 44. Just my $.02. Hope it helps a little
2006 Jeep Wrangler---SOLD!
Nowhere at present is there such a measureless loathing of their country by educated people as in America. --Eric Hoffer
Originally Posted by rmb2485
cheap mods are like a drug dealer giving you your first few for free...they will only get you addicted and before you know it every paycheck goes into your new habit :rofl:
GroundAssault is offline
Banging Sound at Take Off 1st Gear HanksRide YJ Wrangler Technical Forum 16 05-17-2009 08:08 PM
*Thump* Sound - 1st Gear Uphill HiRoller TJ Wrangler Technical Forum 5 05-06-2006 02:26 PM
Rubbing sound while in gear rafael TJ Wrangler Technical Forum 1 04-27-2006 12:34 PM
8.8 and re-gear cost... Sound about right..? mferrari TJ Wrangler Technical Forum 26 04-04-2006 11:55 AM
Weird sound in 3rd gear alw041 YJ Wrangler Technical Forum 1 09-03-2005 12:05 AM
