Bad fuel pump symptoms ? - JeepForum.com
post #1 of 13 Old 03-23-2009, 02:03 PM Thread Starter
chaznad
140,000 miles , how do i know its going bad .
Everything on my jeep is new front to back except this part. New optima battery, starter ,alternator plugs wires , all that.
when i start her up when cold it turns but will take 5 seconds or so, sometimes ill have to resort to a 2nd try but when warm shell fire right up....sound like the fuel pump to you?
Whats the cost of replacing one of these things?
97 TJ 4.0 , 3spd Auto , D30/44 , 3.25 RC lift w/ 1.25" BL / MML , ( 5 )33x12.50x15 Goodyear Duratracs
“Too many people spend money they haven't earned, to buy things they don't want, to impress people they don't like.”
chaznad is offline
post #2 of 13 Old 03-23-2009, 02:26 PM
Dans95ZJ
Easy to check fuel pump. Just turn the key to ON and listen. The fuel pump will go on for about 5 secs and then stop as it reaches the right pressure.
If you want to check the actual pressure, you'll need to buy the gauge, but it's cheap. The fuel rail has a test port that the gauge plugs into. Set it up and measure. Compare to specs: should be 44-54 psi
If you have to replace the fuel pump, it's in the gas tank. I did this on my ZJ without any problem, just getting some gas spills (and always on my face).
Dan
Only in My Jeep!
Dans95ZJ is offline
post #3 of 13 Old 03-23-2009, 02:27 PM
Dans95ZJ
PS: Check your crank position sensor; might be going bad. //dan
Only in My Jeep!
Dans95ZJ is offline
post #4 of 13 Old 03-23-2009, 04:39 PM Thread Starter
chaznad
Dan
What am i listening for, after i turn it to the on position i hear a click after 4-5 seconds , thats it
chaznad is offline
post #5 of 13 Old 03-23-2009, 04:54 PM
Muratus
Are you having any issues when driving? Like lack of power, cutting out, backfiring, etc?
My fuel pump is out right now. I knew it was comming mostly cause when I got ready to start the Jeep I'd have to turn the key and give it a few seconds then crank the engine. Otherwise it would just turn over for 10 to 15 seconds before starting. It was having trouble building up presure. So when all the issues durning driving started up, I already knew what was going wrong.
Muratus is offline
post #6 of 13 Old 03-23-2009, 06:05 PM
kloppk
Not quite... It shuts off based on "x" seconds passing and not due to a certain pressure being attained.
kloppk is offline
post #7 of 13 Old 03-23-2009, 07:31 PM Thread Starter
chaznad
What and where is this ?
chaznad is offline
post #8 of 13 Old 03-23-2009, 08:39 PM
kloppk
Drivers side, top edge of the bell housing...
kloppk is offline
post #9 of 13 Old 03-24-2009, 12:39 PM
Dans95ZJ
Listen for the hum, the click is when it stops.
Probably wouldn't hurt to throw a pressure gauge on the fuel rail test port to see if you got pressure.
Also, if you disconnect the crank position sensor for 30 secs, then reconnect and start the engine. And if you want to be real precise, turn on until you hear that click and then turn the key to start. Should fire right up.
If it cranks and doesn't start, might be the pump.
Hope this helps.
Post what you find andwe'll all take it from there to get you going.
Dan
Only in My Jeep!
Dans95ZJ is offline
post #10 of 13 Old 08-06-2009, 10:36 AM
Aalbury
hope you don't mind me jumping in with a fuel pump question. If i release the pressure in the fuel system, hook my gage up, and turn the ignition key on.. will the pressure only build if the fuel pump is working? Or will I need to disconnect the vaccum pressure to be sure?
Aalbury is offline
post #11 of 13 Old 09-28-2014, 02:50 PM
TRACY1
My jeep cheerokee lorenzo has a strong gas smell when tank is full. It also hesitates at 45-50 miles an hr likes it wants to choke up, any ideas on what it may be.
TRACY1 is offline
post #12 of 13 Old 05-10-2016, 08:10 PM
ryan7676
hope yall dont mind but my jeep has me stumped. i just put a brand new 4.0 in my 97 wrangler. ive checked the timing rechecked and checked a dozen more times. it starts and idles fine but when you go to accelerate it stumbles and spits an sputters. ive replaced pulgs, wires, cap, rotor coil, all the sensors on the throttle body and checked all the injectors. would that be a weak fuel pump? any help would be awesome...
ryan7676 is offline
post #13 of 13 Old 05-11-2016, 08:24 AM
NotURMailman
NotURMailman's Avatar
You really should start your own thread rather than asking an unrelated question in a two year old thread...
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
Fuel Pump Symptoms - Need Help LIGHT-HOUSE YJ Wrangler Technical Forum 38 03-19-2016 03:51 AM
Replace Fuel Pump or Fuel Pump/Sending Unit assembly? Muratus TJ Wrangler Technical Forum 10 02-09-2012 10:08 AM
inline fuel pump or new tank with pump in it? cubbybear YJ Wrangler Technical Forum 2 12-25-2008 06:13 PM
Fuel pump assembly vs. fuel pump? eclipse27 TJ Wrangler Technical Forum 11 11-11-2008 10:18 AM
Would these symptoms indicate a bad fuel pump gary1 YJ Wrangler Technical Forum 6 08-07-2005 11:22 AM
