Bad ECM? alternator won't charge battery - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Bad ECM? alternator won't charge battery
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 08-03-2013, 09:53 PM   #16
Timmay82
Doesn't the PCM regulate the alternator on our Jeeps? I don't think their are internal regulators on our alternators and if that is the case it is usually either the PCM, or more commonly a wire that is intermittently shorting. I would carefully check the wring very thoroughly. If that comes up short I think the dealer can test the PCM but I have no idea of the costs. If the wiring comes up good it is more than likely a PCM issue.
Disclaimer: All opinions expressed, (or even assumed) under the JeepForum user name: Timmay82, are strictly that of somebody else. If you don't agree, feel that you have been attacked and as such your feelings are hurt by the above said user, than you may present any issues that you may or may not have with somebody else!
Timmay82 is offline   Reply With Quote Quick reply to this message
Unread 08-03-2013, 11:30 PM   #17
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Yes it does...
Knuckelhead is offline   Reply With Quote Quick reply to this message
alternator , charging , ecm , pcm , voltage regulator
