Bad ECM? alternator won't charge battery - Page 2 - JeepForum.com
post #16 of 19 Old 08-03-2013, 08:53 PM
Timmay82
Doesn't the PCM regulate the alternator on our Jeeps? I don't think their are internal regulators on our alternators and if that is the case it is usually either the PCM, or more commonly a wire that is intermittently shorting. I would carefully check the wring very thoroughly. If that comes up short I think the dealer can test the PCM but I have no idea of the costs. If the wiring comes up good it is more than likely a PCM issue.
Disclaimer: All opinions expressed, (or even assumed) under the JeepForum user name: Timmay82, are strictly that of somebody else. If you don't agree, feel that you have been attacked and as such your feelings are hurt by the above said user, than you may present any issues that you may or may not have with somebody else!
Timmay82 is offline
post #17 of 19 Old 08-03-2013, 10:30 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Yes it does...
Knuckelhead is offline
post #18 of 19 Old 07-12-2016, 08:48 PM
StephenBForbes
I have a 2002 Liberty Renegade that has been displaying the battery light and I got a P0644 code. It turns out that the voltage regulator is INSIDE the bloody ECM! Flippin' GENIUS WORK Chrysler! How stupid can you get? Wait, you built this damned thing. That says enough.
Anyway, I found an easy solution. I just installed an EXTERNAL voltage regulator kit from Quick Start Alternators. (http://tinyurl.com/jvansy3) It cost me $65.00 and is brilliantly easy to install. It includes absolutely everything needed and solved my problem. This is the way things were done before 1987 and they worked perfectly AND were easy to service. Now, it's all about driving you back to the dealer so that they can rape your wallet as much as possible! The Liberty proves that point very well!
So, if you want an EASY solution, use mine.
Good luck,
Stephen
StephenBForbes is offline
post #19 of 19 Old 07-13-2016, 07:15 PM
Knuckelhead
AFSOC Retired
Do you own a TJ?...
alternator , charging , ecm , pcm , voltage regulator
My alternator wont charge my battery on my jeep!!! pipisnack YJ Wrangler Technical Forum 30 08-01-2012 11:12 PM
ALt will not charge battery psyco-elmo YJ Wrangler Technical Forum 6 02-02-2010 03:23 PM
alternator won't charge on my tj vadio TJ Wrangler Technical Forum 5 06-02-2009 06:25 AM
Alternator is not providing a charge tcmault TJ Wrangler Technical Forum 2 05-05-2009 11:37 AM
New battery + working alternator = battery still won't charge pyro9862 YJ Wrangler Technical Forum 7 10-28-2007 08:51 PM
