BAD!!! drive line vib. - JeepForum.com
post #1 of 28 Old 11-10-2010, 05:59 PM Thread Starter
curt7088
At the beginning of October I took a trip ot Oak Ridge TN to Windrock mountain OHV park and on the way back after leaving the park i stopped for lunch, when i got back on the road i started getting a horrible drive line vibration. I thought it was my u-joints... but it wasn't i changed them, and it was still there. i had the wheels and tires balanced, and i had it diagnosed at a local 4x4 shop they said that i bent the slip yoke... but my drive shaft has not taken a hit0 mph, and the guy there said that when he removed the shaft and got the shaft turning he didn't see it moving or shakeing even up to 70. so i was wondering if anyone could shoot me some ideas, the diff fluid has been changed in both diffs the day after i came back, and the vibration seems to be coming from the rear through the seat.
curt7088 is offline
post #2 of 28 Old 11-10-2010, 06:19 PM
MO2500
So from the park to where you stopped for lunch there was no vibes? Just when you got back on the road?
Instagram: @omsmike
MO2500 is offline
post #3 of 28 Old 11-10-2010, 06:22 PM Thread Starter
curt7088
yes they start at 55 almost exactly
curt7088 is offline
post #4 of 28 Old 11-10-2010, 06:57 PM
bairy
Lets start here:
Put the jeep in 4-high and remove the rear driveshaft and drive it around....
does the problem persist?
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #5 of 28 Old 11-10-2010, 07:01 PM
williambmac
Check for a broken trans mount.
2000 TJ 5.5 Long arm, lots of extras. R.I.P.
2005 LJ rubi 35's Clayton, lots of extras
williambmac is offline
post #6 of 28 Old 11-10-2010, 07:58 PM Thread Starter
curt7088
I shall do both in the am...
curt7088 is offline
post #7 of 28 Old 11-15-2010, 02:17 PM Thread Starter
curt7088
ok, took the driveshaft out put it in 4Hi drove it, the vibration was still there but sooo very slight it was 100x's better.... so i believe the shop i took it to may be right, checked the transmission mounts and they are all intact and OK... but put it back in 2wd with the driveshaft out and had it turning like 80, and the output shaft on the tcase didn't visibly shimmy, shake, or anything... any other ideas???
curt7088 is offline
post #8 of 28 Old 11-15-2010, 03:02 PM
bairy
100x better most likely means:
-Pinion angle is bad
-Bad Ujoints (yes, I know you changed)
-driveshaft out of balance.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #9 of 28 Old 11-15-2010, 05:37 PM
509media
1930 JK Wrangler
Sometimes a tranny mount can appear to not be broken. Put something around the tires to keep the Jeep from rolling. Parked on a flat surface of course. LOL Put the Jeep in neutral. Lay on the ground and push against the driveshaft with your foot. Does the tranny move around a lot? If so more than likely you have a broke tranny mount. It is much easy to check with the Jeep in neutral. Not sure you checked it that way. Just thought I would mention it.
Check the yoke on the rear axle. I have had a couple Jeeps come in the shop over the years with a broken yoke. The tiny ears that hold u-joint center and the caps on can break off. Make sure they are still on there. If not the driveshaft may not be bolting back on the yoke centered.
If you are running a cv shaft a broke cv can cause issues like this. I would recommend inspecting it. Again place the Jeep in neutral on a flat surface. Make sure the Jeep can not roll. Grab the driveshaft and see if it moves around. If so this can point out faulty u-joints, cv's, and other issues. If the Jeep is not in neutral with load off of the driveshaft this problem may be harder to see.
The weight on welded to the side of stock driveshafts to balance them can get knocked off easily. I would also check this.
Dan
Dan DuBose
<<<"I Build Stuff">>>
www.509media.com
509media is offline
post #10 of 28 Old 11-15-2010, 06:46 PM Thread Starter
curt7088
the vibration was still there, the jeep is not lifted, how can the pinion angle be bad... and the vibration is still there when a different driveshaft is installed
i checked the transmission mounts visually and then layed under it while strain was put against the tranny in reverse and drive... i will check with my foot against the driveshaft tomorrow to see if the tranny mounts are broke.
curt7088 is offline
post #11 of 28 Old 11-15-2010, 07:04 PM Thread Starter
curt7088
Dan
i'm running a stock driveshaft with no lift and the ears are still there checked those. the yoke is centering checked that.
The wierd thing is the vibration gets better without the rear driveshaft, but is not eliminated, i'm sorry if i did not explain that fully in my earlier post, is there a chance that the rear axle could be causing this vibration? someting internal with the pinion and crush nut, i did notice that there is a slight slack in the yoke on the rear, not sure if that makes a slight difference... thanx for the input guys this is really gettin on my nerves and i want to get it nipped, but then again i had it diagnosed, but i wanted to make sure that the shop that diagnosed it wasn't trying to lay one over on me,
curt7088 is offline
post #12 of 28 Old 11-15-2010, 07:34 PM
bairy
I did not realize you were 100% stock. sorry...
yes, you could have some slop and or something wrong with your rear end. It is hard for us to diagnose it online.
Check the play/backlash of the pinion, pinion nut, yoke, and even pull the rear cover to inspect the diff.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #13 of 28 Old 11-15-2010, 07:55 PM
509media
1930 JK Wrangler
When you do a couple of the tests I mentioned push and pulling on the driveshaft you should be able to see if the pinion bearings are still tight in the rear axle. If the pinion bearings are in bad enough shape to cause vibration like you are experiencing I would venture to say you will have sound to go with it. I would take a look. Only rule things out when you know they are not the cause.
My guess with the information is going to be tranny mount. A visual inspection will not tell you for certain if it has failed in some cases.
Let us know after you have had to push around on the driveshaft. Like I mentioned before make sure to do this with it in neutral.
Dan
Dan DuBose
www.509media.com
509media is offline
post #14 of 28 Old 11-15-2010, 08:10 PM Thread Starter
curt7088
thanx
curt7088 is offline
post #15 of 28 Old 11-15-2010, 08:26 PM
Farmkid
Its possible thone of those u-joints are bad. I installed 2 new joints in the rear and after about 2 weeks of driving the needle bearings in one of the "new" joints looked like powder stirred in grease.
Farmkid is offline
Drive Line Noise when Warmed up from extended drive amytom TJ Wrangler Technical Forum 1 02-26-2009 02:11 PM
Bad Drive Line Clatter SportTJ4x4 TJ Wrangler Technical Forum 5 11-02-2008 08:34 AM
vibrations from drive line? Pathogen1337 TJ Wrangler Technical Forum 3 04-26-2008 08:11 AM
Drive Line Issue Teethofryan YJ Wrangler Technical Forum 1 02-20-2008 07:04 PM
Need drive line help please newbs TJ Wrangler Technical Forum 1 09-25-2007 04:26 PM
