Is it bad to change your AT fluid? (32rh) - Page 3 - JeepForum.com
post #31 of 35 Old 07-16-2010, 12:14 AM
WsRpAoNrGtLtEjR
Originally Posted by 97yellow View Post
whats the process for checking the trans fluid? do you keep it running to check or turn it off? the manual is a little fuzz about what you do . it doesn t say to turn off or leave running.
The engine is supposed to be warmed up and running, and you're supposed to be in Neutral.
WsRpAoNrGtLtEjR is offline
post #32 of 35 Old 07-16-2010, 12:28 AM
WsRpAoNrGtLtEjR
Originally Posted by tjkj2002 View Post
It may seem a waste of money but I flush my trans every 15,000 miles(filter change every other flush) and use the correct fluid,but in over 20 years of driving I have never had a trans failure and I'm hard on vehicles(very hard).
This, IMHO, is how every vehicle should be taken care of. If I was the original owner of my Jeep, my 32rh would've been getting flushed that often from the beginning. I'd much rather spend the $90-$100 on a flush once a year or so, then run into far more expensive problems down the road.
And to the OP, if your fluid really is brown/burnt, I definitely wouldn't flush. I, personally, would let it be, because it'll probably still last you a while. Save up cash in the meantime so you'll be ready for an overhaul when the time comes. And if it never does, you can spend that cash on other mods! (That's exactly what I did)
post #33 of 35 Old 07-16-2010, 08:15 PM
LMoscar45
I can't see how anyone would advocate letting it be as the best course of action. If you choose not to swap the fluid regardless of means, you should at lease add an additive restorer like lubegard, etc. This would satisfy any apprehensions concerning swapping the fluid, and restore the necessary additives to the fluid. If you are ridiculously concerned about fluid levels, suction out 10 oz of old fluid and dump int he 10oz bottle of lubegard.....just trust me and spend the $15 bucks.
Leaving burnt fluid will yield nothing positive. A 2 minute conversation with your local transmission builder would be beneficial.
LMoscar45 is offline
post #34 of 35 Old 07-18-2010, 06:26 PM Thread Starter
TheRover
I'm just going to add some lubegard and hope for the best. When it dies and i get it rebuilt then I'll worry about changing the fluid on schedule. And I'll install a tranny cooler and temp gauge.
Sound like a good plan?
2.5" RC, 33x12.50 Duratracs, 15x8 Pro Comp 7031, Smittybilt rocker guards, Kenwood marine, Polk marine, and Infinity audio.
TheRover is offline
post #35 of 35 Old 07-22-2010, 07:20 PM Thread Starter
TheRover
Ok. So, yesterday, I noticed a spot on the concrete under the tranny pan. I checked the area out with a flashlight, and it was wet.. in a lot of places. Wind from driving probably blew the fluid around some. So i'm not sure where it's coming from but it was dripping from the rear section of the pan (most likely because that's the lowest point on the transmission in that area). I cleaned it all off so i'd be able to tell where it was coming from.
I drove it around today, and so far there's nothing. The leak appeared overnight, after a day or two of not being driven (as far as I can remember). We pulled the dipstick, and of course it's all brown. Well, this time it showed it as being overfull. Also, there were a few bubbles in the fluid too, which is not normal. I don't think we noticed either of those things the first time we pulled it.
Link to AT stuff
^ That website says that the bubbles could be caused by:
-Overfull AT fluid
-Not enough AT fluid
-(if the fluid is milky brown) a leak in the AT fluid cooler, so it's mixing with coolant
-Plugged transmission vent
-Wrong ATF
There's enough AT fluid, and i'm 99% sure there's right kind of fluid in there.
As for the other things, I'm going to have to pull some fluid to see if it's milky brown or not. Also, doing that paper towel test suggested on the website isn't a bad idea either.
I'm just worried that there might be coolant in the fluid. Because then we'd have to change the fluid, and risk killing the transmission...
Any ideas?
-Jason
TheRover is offline
32rh , atf , automatic , change , fluid , maintenance , transmission
So I found out today... (low fluid and fluid leak with 32rh auto) Speed94 TJ Wrangler Technical Forum 43 08-26-2010 09:45 AM
32rh auto problems (dirty fluid) gabriel05 TJ Wrangler Technical Forum 2 07-01-2009 08:19 PM
32RH gasket and filter change UTWeezul TJ Wrangler Technical Forum 6 02-03-2007 05:43 PM
Synthetic ATF fluid in 32RH Auto tranny? david.mciver TJ Wrangler Technical Forum 3 12-14-2004 06:45 AM
32rh tranny swap. change input gear?? dupwee00 TJ Wrangler Technical Forum 1 03-25-2003 09:19 PM
