Bad ball joint or not? - JeepForum.com
post #1 of 2 Old 08-17-2005, 06:12 AM Thread Starter
hkiss96
I've got a 6" skyjacker lift and recently had to replace some bushing in the front end. After the work, it's been squeaking more than before. So I looked underneath to see if I need to add some grease and noticed something odd with a ball joint.
On one of the ends, the ball side/end had a shim (or something that looked like that) move off center. It looks like it should be in line with the rod. Without a pic it's difficult to explain. I'm trying to find out if this needs to be replaced or can just be fixed/moved into the correct position etc. Would that be something that I can do myself (I have very few tools)?
hkiss96 is offline
post #2 of 2 Old 08-19-2005, 07:00 AM
Hunter9
Hunter9's Avatar
can you post a pic?
97 Sport 4.0l Auto D30/D35
RE 3.5 SF, 1" BL, 1" MML, 285/75/16 (33") MTRs, 16x8 MT Classic Locks, 4.10 gears, Lockrite Front, Warn Front and Rear Bumper w/ Tire Carrier, Warn Diff Skids, Rock-it Man Rockers, Jeeperman Front Hoop, M8000, A to Z winch mount, Hella 500s, H4 Conversion
Former 3.07 Gears Club Member #1
Hunter9 is offline
Ball, joint, U-joint, control arms? Clunking noise. FritzTJ TJ Wrangler Technical Forum 11 09-18-2009 10:59 AM
U-Joint and Ball-Joint question gcally TJ Wrangler Technical Forum 5 02-18-2009 10:28 AM
Lift Control Arms: Ball joint vs Heim Joint types? CB3 TJ Wrangler Technical Forum 5 04-21-2007 12:27 AM
new ball joint jeep lif TJ Wrangler Technical Forum 5 03-05-2007 04:20 PM
front wheel problems (u joint, ball joint etc) ohhpe YJ Wrangler Technical Forum 0 06-05-2005 03:40 PM
