Backspacing On Stock TJ Rims - JeepForum.com
post #1 of 8 Old 10-07-2004, 08:02 AM Thread Starter
brrempel
brrempel's Avatar
How much is the backspacing on stock 98 TJ rims as seen in my avatar?
brrempel is offline
post #2 of 8 Old 10-07-2004, 08:12 AM
Optik45
Backspacing on stock wheels is 5.5"
2000 Shale Green Sport, I6, 5spd.
3.5" RE Standard
1" MORE BL
1" MORE MML
33x12.5" BFG MTs on Tech-1 Rock Crawlers
KC 130W Long Range Slimlites mounted on Windshield.
JKS Quick Disconnects
and a lot of other trinkets
Optik45 is offline
post #3 of 8 Old 10-07-2004, 11:59 AM
Winters
Winters's Avatar
I was told stock backspacing is 5"...they could've been pulling my leg though.
~Brad~
07 Black JKU Sahara
Been there:
06 IO Rubi, 04 Black TJ Sport, 02 Amber Fire TJ SE, 93 White YJ
Winters is offline
post #4 of 8 Old 10-07-2004, 12:43 PM Thread Starter
brrempel
brrempel's Avatar
I'm trying to decide if I want to put my stock TJ rims on my wifes XJ, but I don't want to if the TJ rims have more backspacing then the XJ. The XJ is 5.25 so if the TJ is 5.5 I wont put them on, bit if it's 5.0 then I will. Anyone out there that can say for sure?
brrempel is offline
post #5 of 8 Old 10-07-2004, 04:44 PM Thread Starter
brrempel
brrempel's Avatar
bump............
brrempel is offline
post #6 of 8 Old 10-07-2004, 06:21 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Why don't you just measure the backspacing on your spare tire wheel? Every TJ wheel I've seen has 5.5" but I haven't measured every single one they now sell.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #7 of 8 Old 10-07-2004, 09:16 PM
Tgoose
For sure the gamblers are 15x8 w/5.5"bs. More than likely your XJ rims are 15x7 w5.25bs.
'98TJ Sahara,02 Liberty
Tgoose is offline
post #8 of 8 Old 10-08-2004, 12:44 AM
COJeep2004
Moab rims found on the Rubicons (16x8) are 5" back spacing. Just picked up a set. They stick out just perfect. 5.5" on the old Ravines (15x8).
COJeep2004 is offline
Upgrade stock tires/rims with larger stock tires/rims (08 Wrangler Unlimited)QUESTION makstuss JK Wrangler Technical Forum 3 02-20-2011 04:23 PM
backspacing on stock rims? jeepskater433 TJ Wrangler Technical Forum 5 01-07-2009 05:40 PM
Reverse the stock jeep steel rims for better backspacing? loudog3114 TJ Wrangler Technical Forum 5 10-16-2005 07:59 PM
Backspacing on Stock Grizzly Rims? Drjones266 TJ Wrangler Technical Forum 2 04-11-2004 07:16 PM
Backspacing of stock rims mdepot TJ Wrangler Technical Forum 1 12-12-2003 09:17 PM
