Backspacing - JeepForum.com
post #1 of 2 Old 04-24-2008, 05:34 AM Thread Starter
MadManMIke
Backspacing
Just put a Rustys 3" lift on my Rubicon Unlimited. Im going to be getting 33x12.50 --15 MT's . Since I need new rims for this I would like some recommendations as to the correct backspacing I'll need for this setup. Remember this rig has D44's--if that makes a difference--
Mad Man Mike -
MadManMIke is offline
post #2 of 2 Old 04-24-2008, 06:13 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
You need 4.5" at most.
If you want the tires tucked under the flares as much as possible, go with the maximum 4.5".
If you want a little wider stance, go with 3.5" - 4".
Wheelin98TJ is offline
Confused about backspacing and overall wheel size (What backspacing for a TJ?) uknowwho TJ Wrangler Technical Forum 21 10-03-2009 10:12 AM
90 YJ Backspacing? andrewbranch06 YJ Wrangler Technical Forum 4 11-30-2008 10:17 AM
backspacing?! H2who YJ Wrangler Technical Forum 5 06-11-2005 05:48 PM
Backspacing tj01wrangler TJ Wrangler Technical Forum 9 05-25-2005 10:03 PM
Rim backspacing? Gritz TJ Wrangler Technical Forum 3 04-06-2005 02:39 PM
