Backpressure question - JeepForum.com
post #1 of 12 Old 05-01-2007, 05:21 AM Thread Starter
djaychris
I'm thinking of putting a flowmaster 40 on my wrangler. I will be keeping the stock cat and manifold. I'm concerned about backpressure, as I don't want to loose my low end power. Does anybody know if the flowmaster 40 is too wide open for the wrangler? Also, does the 40 series have a tendency to drone loudly?
-Thanks
-Dan
2006 Silver Metallic X
I promised the wife I'd keep it stock............I lied.
-Earn some jeep money at
djaychris is offline
post #2 of 12 Old 05-01-2007, 06:55 AM
Rocky529
Rocky529's Avatar
The Flowmaster 40 is great and has no negatives about it.
It does not drone at all, at highway speeds, I can't even hear it. It is perfect for my liking.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 12 Old 05-01-2007, 09:47 AM
wahooz04jeep
X2 aggressive enough to like but not too loud.
2007 Jeep Patriot Sport
OlllllllO
I wave
wahooz04jeep is offline
post #4 of 12 Old 05-01-2007, 01:39 PM Thread Starter
djaychris
Thanks guys, thats what I'm leaning for. What size diameter did you go with, 2.25? Any power loss issues? It didn't make your gas mileage worse did it?
-Thanks
-Dan
post #5 of 12 Old 05-01-2007, 01:46 PM
Rocky529
Rocky529's Avatar
-Thanks
-Dan
I believe it is a 2.5" diameter and I recall the shop welding on adapters to fit my 2.25" pipe. I was watching from outside the garage so I can't be sure. Either way, I am using my stock 2.25" pipe... no need for a bigger diameter.
No, it didn't make my gas mileage worse. Don't worry about gas mileage, life is too short.
Rocky529 is offline
post #6 of 12 Old 05-01-2007, 01:57 PM Thread Starter
djaychris
Rocky,
Just curious, did you buy yours online? If so, what was the offset and/or part number? What kind of tip did you use? I don't want a tip that I'm going to have to clean constantly.
-Thanks
-dan
post #7 of 12 Old 05-01-2007, 01:59 PM
Rocky529
Rocky529's Avatar
Rocky,
-Thanks
-dan
I had a local shop install mine. They had it on hand. I don't have any off-set measurements. I remember seeing them on this forum though so if you run a search for "Flowmaster 40", I'm sure you will find what you need in no time. I would have ordered it online and installed it myself except for the fact that I don't have a welder 'nor do I know how to weld. I couldn't say no when they charged my ~$115.
I did not want a chrome tip or anything of that nature. I left it completely stock. You can not tell I have a Flowmaster 40 unless you crawl under my Jeep and look... or of course if you open your ears and hear the sweet sound.
Rocky529 is offline
post #8 of 12 Old 05-01-2007, 02:07 PM
Rocky529
Rocky529's Avatar
djaychris, clear your PM inbox.
Rocky529 is offline
post #9 of 12 Old 05-01-2007, 03:13 PM Thread Starter
djaychris
Thanks for the advice. My inbox is cleared for ya.
-Dan
post #10 of 12 Old 05-02-2007, 09:30 PM
STW
Curious too about the specific backpressure question. This used to be discussed a lot on the forum: whether 2.25" was necessary to preserve backpressure (felt as low rpm torque) or whether you could open it up with 2.5" (for a little better high rpm hp performance) and still keep enough backpressure. Don't remember what they decided for the I6, but I remember that folks felt the fourbanger was better off with the smaller diameter. Because the I6 has a non-restrictive intake it stands to reason that it could take some opening up of the exhaust without losing bp (IIRC the 2.5 and the 4.0 use the same dia. exhaust).
2000 2.5 TJ, 5spd, 33s, 8274
STW is offline
post #11 of 12 Old 05-02-2007, 09:47 PM
Red_
2016 KL Cherokee
I'm running a 2.5 inch pipe from the cat back and have felt no loss in low end torque.
Red_ is offline
post #12 of 12 Old 05-03-2007, 03:36 PM Thread Starter
djaychris
I'm probably going to stick with my factory plumbing for now, and just throw on a flowmaster with the stock tip.
-Dan
Lift/Tires question and Cleaning soft top & engine question Bryan_16 TJ Wrangler Technical Forum 16 05-19-2012 03:25 PM
Backpressure normal on stock exhaust? TJ4JT TJ Wrangler Technical Forum 5 11-02-2009 01:36 AM
Tire question(noob question but just a quick answer needed) 07SilverX JK Wrangler Technical Forum 3 12-25-2007 03:35 PM
Flowmaster Backpressure problem or no? bradb511 TJ Wrangler Technical Forum 2 02-08-2005 03:10 PM
2.5l and backpressure Greencar YJ Wrangler Technical Forum 2 07-09-2004 11:02 AM
