Backpressure normal on stock exhaust? - JeepForum.com
post #1 of 6 Old 11-01-2009, 08:18 PM Thread Starter
TJ4JT
2015 JK Wrangler
2004 TJ Sport, 242ci I6, 5sp man... The RPM drop after a rev is a little slow for my liking. I would think that the quicker it is able to drop back to idle would be better. I feel like I'm not getting as much power to the wheels or trans b/c of the back-pressure. I'm not a mechanic, that's why I'm asking. Am I right? Do most people upgrade the exhaust, or is it something that most of the time is overlooked?
"Only those willing to go too far will ever know how far they can go"
__________________________________________________ ____
'04 TJ Sport, 4.0L I6, 5-speed Manual stock tran/transfer case3 1/4" Rough Country Suspension lift, Rancho RS9000 shocks
TJ4JT is offline
post #2 of 6 Old 11-01-2009, 08:34 PM
Max-Q
1983 CJ7
Some backpressure on a normally aspirated engine is needed. The speed the engine revs up and down would be more related to the weight of the flywheel rather than the engine's backpressure.
1997 Jeep TJ
1983 Jeep CJ7
2011 JK Unlimited Rubicon
Max-Q is offline
post #3 of 6 Old 11-01-2009, 09:07 PM Thread Starter
TJ4JT
2015 JK Wrangler
Hey, Thank you for the insight. On an unrelated note, how do you like the rhinoliner? How much was it to install? How long was the cure time, if any? Do you still use your floor mats? I want to do it, but it's kind of semi-permanent, and I don't want to do something I'll regret...
TJ4JT is offline
post #4 of 6 Old 11-01-2009, 09:32 PM
dbbd1
dbbd1's Avatar
You really would not like my Taco. An '07 6-speed manual but the computer artificially keeps the RPM's hanging between shifts for some emissions reason. (yeah, if that really makes sense- burn more gas=lower emissions)
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #5 of 6 Old 11-01-2009, 09:39 PM
Dmcastino
You aren't going to see any real gains in power from exhaust mods if thats what you are asking. Oh and I have the Rhino liner too, and you definitely won't regret it! The only thing I regret is not doing it myself with U-POL Raptor. I paid $650 to have mine done and that included me tearing out the interior, where as I could have done it myself with the other kit for about $130 and I'm 100% sure my application would have looked more professional, which was unfortunately the entire reason I paid to have it done in the first place. Oh and to answer your other questions, I don't use floormats, or drain plugs for that matter and it was cure a day or two after they finished spraying, smell lasted a few days after that
Dmcastino is offline
post #6 of 6 Old 11-02-2009, 01:36 AM
wushaw
Rockin jeep
wushaw's Avatar
You must not be married
wushaw is offline
is 2300rpm @60m/h or 100KM/H higher than normal for stock? greentea TJ Wrangler Technical Forum 4 09-22-2008 08:31 PM
Weird smell normal for new exhaust? chan TJ Wrangler Technical Forum 9 12-28-2007 07:21 PM
Exhaust smell normal??? - 05 Wrangler X Freakzilla TJ Wrangler Technical Forum 10 10-27-2005 08:28 PM
Smell after installing new exhaust manifold gasket - normal? Dogman TJ Wrangler Technical Forum 3 01-01-2005 12:43 AM
Normal wall thickness of exhaust tubing? Stricken TJ Wrangler Technical Forum 3 07-20-2004 09:58 PM
