back up lights problem - JeepForum.com
post #1 of 2 Old 02-23-2014, 05:11 PM Thread Starter
glowe
The backup lights work, but only when the shifter is halfway between reverse and neutral. Where is the switch located for the lights, and is it adjustable?
glowe is offline
post #2 of 2 Old 02-23-2014, 10:08 PM
goodwrenchdave
Not adjustable and its the park neutral on the auto trans. On the trans itself. Make sure your linkage isn't out of adjustment ( it is adjustable- but chances are that if you can start in park & neutral, it is adjusted ok)
goodwrenchdave is offline
