B&M supercooler on TJ transmission - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > B&M supercooler on TJ transmission
Save 17.76% for the 4th of july with ruffstuff specialtiesIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSave on AEM Intakes from XT!
Unread 06-15-2015, 08:52 AM   #1
sedanss
I've been doing allot of of research on adding a transmission cooler to my 04 TJ 4.0 42rle. I really like the derale setup, but I have a almost new B&M hi-tek supercooler off of one of my other cars. I'm not really worried about mounting it since I'll fab something to mount it in front of the radiator. But I was wondering if anyone has run this cooler on their TJ? Its on the bigger size and I know some times there is a worry about over working the pump in the transmission. What do u guys think? This is the cooler I have:
B&M 70297 Hi-Tek Transmission Cooling System http://www.amazon.com/dp/B000CIIE1W..._aLUFvbS1EM28B
sedanss is offline   Reply With Quote Quick reply to this message
Unread 06-15-2015, 11:22 AM   #2
JBTJ
It's a good cooler and no need to worry about the pump, it's not going to hurt a thing. Install it and enjoy it's benefits.
JBTJ is offline   Reply With Quote Quick reply to this message
Unread 06-15-2015, 05:06 PM   #3
pwmac
B&M 70297 Hi-Tek Transmission Cooling System http://www.amazon.com/dp/B000CIIE1W/..._aLUFvbS1EM28B
Read http://www.jeepforum.com/forum/f9/ke...1/index27.html
Post 398 & 405
Update: I had to add a thermostat* to keep the trans from being to cool. Now I have a steady 180F even going up the major mountain passes.
*Permacool 1060
BTW other B&Ms can be had with the cold bypass = thermostat.
pwmac
Durango, CO
06 Rubicon, modified
pwmac is offline   Reply With Quote Quick reply to this message
