Axles - JeepForum.com
post #1 of 8 Old 08-04-2010, 11:17 PM Thread Starter
Telnet
Axles
I have a 2001 tj and im going to swap the fluid for new. and do i need friction modifier to add to the oil or ???
I have
dana 30
dana 35
Also what RTV should i use ??
Thanks Jacob
Telnet is offline
post #2 of 8 Old 08-04-2010, 11:38 PM
Sundowner
Friction modifier? What the hell is that? Check the FAQ that lists those kinds of things...
http://www.jeepforum.com/forum/f9/fa...cities-489932/
Sundowner is offline
post #3 of 8 Old 08-04-2010, 11:41 PM Thread Starter
Telnet
"*4 oz of friction modifier is required with Trac-Lok limited slip differential." im not sure if the axles have the Trac-Lok
Telnet is offline
post #4 of 8 Old 08-04-2010, 11:50 PM
Sundowner
Sorry...wasn't thinking. My axles don't use it and I forgot that some limited slips do.
Most of the time, you won't have any problems if you just use a gear oil that's recommended for use in limited slip axles. It will say that on the container. Sometimes, you might have to buy an additive, but don't do this up front...just change the oil and see what happens. If you start hearing a chirping from the rear, add a little bit to the pumpkin to quiet it.
post #5 of 8 Old 08-05-2010, 05:47 AM Thread Starter
Telnet
does a 2001 tj dana 30, dana 35 have a limited slip ??
Telnet is offline
post #6 of 8 Old 08-05-2010, 11:04 AM
GringoLoco
GringoLoco's Avatar
Some do, some don't. I believe it was a factory option. I have a 2000 with the 30/35 combo, and 3.73 gears, and mine does have the trak-lock, so I use a friction modifier in the rear only, along with oil for limited slips. I'm not sure if the trak-lock came on all 3.73s or not. If you're not in a hurry you can always request a free build sheet and see what it says. The tag on the axle MIGHT say if you have it or not too. I'll go check mine and see if it does.
YELLOW Jeep Club Member #5606
13 mpg - edit: 12 mpg
No hi-lift on the hood (yet)
Odd noises
Still can't get it to take off from a treadmill....
GringoLoco is offline
post #7 of 8 Old 08-05-2010, 11:08 AM
GringoLoco
GringoLoco's Avatar
Just checked. The little tag on my pumpkin specifically states "USE LIM SLIP LUBE" so that's also how I knew I had it. See if it says it on your tag. It'll be the tag that is only held on by one bolt, on mine it's on the right side. As for RTV, I just used the black stuff, I think it just said RTV gasket sealant or something.
Odd noises
post #8 of 8 Old 08-05-2010, 11:12 AM
mdm
Farm Wheeler
How about he determines whether or not he has a limited slip differential and then puts the proper fluid in it?
If you have stock differentials the front D30 is open and doesn't need the friction modifier.
Jack up the rear wheels and rotate one of them. If the opposite wheel rotates in the same direction you have the trac-loc and need the friction modifier. If the opposite wheel rotates in the opposite direction you have an open differential and don't need the friction modifier.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
rtv , fluid , axle , d30 , d35 , dana 30 , dana 35
Dodge axles VS Ford Axles???? Allen52105 YJ Wrangler Technical Forum 7 08-07-2009 02:23 PM
Swapped axles- No ABS on new axles????? suprman4real YJ Wrangler Technical Forum 2 05-11-2009 08:52 PM
94 axles to 91 Axles Brake issue???? lawson1273 YJ Wrangler Technical Forum 1 12-13-2008 11:10 AM
New JK Axles/Mopar Performance Axles Badcbr TJ Wrangler Technical Forum 8 08-21-2007 05:36 PM
Superior axles vs. Alloy axles BusyDoinNothing TJ Wrangler Technical Forum 21 06-30-2007 01:40 AM
