Axle upgrade, time for a Dana 60? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Axle upgrade, time for a Dana 60?
Poly Door Hinge BushingsStainless Steel Door Hinge PinsNew Knuckles Skid Plate at JeepHut
Unread 05-14-2010, 08:03 AM   #1
Jetscuh
O rly?
Jetscuh's Avatar
2012
I am looking to upgrade my rear axle.
This is my issue:
I am leaning toward going with a RockJock Dana 60. I'll probably just go with a Detroit locker again seeing as mine served me well in my current axles and will probably be keeping the 4.56 ratio.
My question is, I will mainly be running 35x12.50 tires on my Jeep (for the next year or so, I do plan to go bigger eventually). Will I really lose a significant amount of clearance running the RockJock Dana 60 in comparison to running a TJ Rubicon Dana 44 (current axle)?
I think that I will have a stronger rear end for sure going with the Dana 60. Then, when I go to upgrade past a 35 inch tire I don't have to worry about doing an axle swap.
I am just curious as to the clearance of a Dana 60.
Also the suspension will be a 4.5" Long Arm if you're wondering.
I am for sure wanting to do an axle swap, just looking for input on the Dana 60 being worthwhile.
Jetscuh is online now   Reply With Quote
Unread 05-14-2010, 08:41 AM   #2
Alex74012
when i was lookin at the rockjocks,the jk ones come with outer c's,but the tj version doesnt.i dont get why
they said to use your stock dana 30 ones,why would you dump the money then have to run dana 30 outer c's?
that dd rubi on 37's
Alex74012 is offline   Reply With Quote
Unread 05-14-2010, 08:45 AM   #3
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The RJ 60 axles have great ground clearance.
I'm fairly certain they have more clearance under the diff than a D44, but I cannot back that with proof or numbers.
The only reason to do it is to save money.
I agree though - its a pointless upgrade if you keep the TJ outer stuff.
Wheelin98TJ is offline   Reply With Quote
Unread 05-17-2010, 08:37 PM   #4
Jetscuh
O rly?
Jetscuh's Avatar
2012
Well, this thread has plenty of views but not many replies.
The final outcome is that I ordered the RJ Dana 60. Keeping the 4.56 gear ratio and a Detroit Locker will be in it as well. I also decided to order a disk brake conversion. Quite excited.
Unread 05-17-2010, 09:00 PM   #5
Apex
Recon death squad
Apex's Avatar
Is this the kind of stuff you can afford when you stop buying meat? If so, I am going to become a vegetarian very quickly
Apex is offline   Reply With Quote
Unread 05-18-2010, 06:54 AM   #6
Jetscuh
O rly?
Jetscuh's Avatar
2012
Yep.
I'm telling you, there are many perks to being a vegetarian.
Unread 05-18-2010, 07:10 AM   #7
emev0l
Prices are coming down, you can have a D60 and have money left over for steak.
Dana Model 60 Rear RockJock Axle Assembly by G2 and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware-RH1
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline   Reply With Quote
Unread 05-18-2010, 07:29 AM   #8
Alex74012
i was looking at this one and they say it comes with 1ton outer knuckles
my gf is screaming at me right now saying hell no!
Dana Model 60 Front RockJock Axle Assembly by G2 and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware-RH1
Unread 05-18-2010, 07:54 AM   #9
emev0l
I bet she's gonna say more then hell no when you break your D44's on 37's, just tell her if you buy the axle now you can still sell your D44 and get some money back, after you break it your not getting much out of it.
Is her birthday coming up? You can buy her the D60 for your jeep.
Unread 05-18-2010, 08:01 AM   #10
Alex74012
Mine is hahaha
i wonder what you have to do to your d-shaft?
Unread 05-18-2010, 08:11 AM   #11
Jetscuh
O rly?
Jetscuh's Avatar
2012
Lol that's a good argument to present.
I don't need money for steak, as I really don't eat it. I guess I could buy my boyfriend a steak though.
Anyway, the RJ Dana 60 was just a couple hundred dollars more than the a Dana 44 (If I were to buy one brand new) and stronger. It also gives a lot of clearance.
Honestly, the only Dana 44 I'd put in my TJ again would be a waggy 44. The TJ Rubicon 44's really aren't that great when it comes to strength. The axle tubes especially. Although, someone might argue with me for speaking against the all mighty Rubicon Dana 44 until the cows come home (which, I am not sure they're ever going to). Granted, they are better than a stock Dana 35 I suppose.
I also have to do some maintenance to my rear drum brakes, so I decided to just go ahead and do a disk brake conversion too. Might as well. It's going to be weird to not hear a chorus of squeaks as my drum brakes lock up on a rainy day.
Unread 05-18-2010, 08:21 AM   #12
emev0l
ooooo your a female, I'm glad I didn't say something about what kinda man doesn't eat meat lol
I personally went for a built rear 44 because I got a really good deal on a brand new one and I'm not going bigger then 35's on this jeep.
The RJ D60's have the same ground clearance at the diff as a D44, there just heavier, but much stronger, the prices are getting better and better and I think it's the best way to go.
A lot of people are going with bolt in 8.8's and they seem happy with them.
Planning on a RJ 60 for the front to?
Unread 05-18-2010, 08:28 AM   #13
jeepinmichguy_
No longer a Jerk....
jeepinmichguy_'s Avatar
your new avatar..... im lovin it!
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
Special thanks to the following vendors for supporting the TJ of the Month contest:
jeepinmichguy_ is offline   Reply With Quote
Unread 05-18-2010, 08:31 AM   #14
Apex
Recon death squad
Apex's Avatar
Thank you One of Harlan, KY's many rock gardens.
Unread 05-18-2010, 08:53 AM   #15
Jetscuh
O rly?
Jetscuh's Avatar
2012
I may run another RJ 60 in the front. Or do some fab work on a Waggy 44, since we have a few of those laying around. We'll see in a couple of months.
I considered an 8.8 for about...5 seconds. They are very hard to find around here and I'd still have to lock it, regear, pay for whatever brake parts and it'd still be a C-clip axle. Don't get me wrong, I don't think it's a bad rear end and I am certainly not knocking those who choose to do that swap. I think it can be a very economical swap for some people as well.
I now have to wait 4-6 weeks since it's a custom order. Oh the suspense.
axle , axle upgrade , dana 60
