#1 | |
Axle Upgrade
I was just wondering if anyone could tell me any other way to beef up my axles besides re gearing and adding lockers. I realize that everyone will suggest just going to 44's but right now that isn't in my budget. Any thoughts would be awesome. Thank you.
#2 |
Lockers and regearing wont do anything for the strength of the D35. It actually would increase the chances that you will break it. You could replace your shafts with 27 spline alloy shafts for about $200, but thats a bandaid in most peoples opinion, or you could do a Super 35 kit for about $1k but then you have to pay to setup your gears again. Another option is a ford 8.8, but by the time your done you could have as much in it at a brand new D44. 4 Wheel Parts can get you a new D44 already set up for a TJ with a detroit, 30 spline alloy usa shafts and the gears of your choice for $2230, which seems expensive, but that is out the door so you dont have to pay $500 for shipping.
Before anyone suggests staying away from 4 wheel parts or this other place has free shipping, you must take into consideration that free shipping only applies to the 48 states, not Hawaii. Just to put things into perspective. I shipped my bicycle which was broken down in a hard plastic case through UPS. It weighed 67lbs and cost me $350.
98 XJ Sport with 4.5" lift, 31" MTZs, and other goodies. |
#3 |
I appreciate it I will look into through 4WD. If I could both the front and rear set-up like that for under 6K I would go that direction. But I am just curious as to how much they would charge me for install.
#4 |
Your front axle is a D30 and it is not that big of a concern. You can put alloy shafts in it and it will hold up great.
http://www.northridge4x4.com/proddetail.php?prod=ALLOYUSA-FRONTAXLE-KIT Your rear axle is a concern if it's a D35 and I'm assuming it is. A D35 will have a rubber fill plug. You need to know what gear ratio you have. It can make a big difference in your plans. If you don't know go look at this tag and it will tell you. Look for 3 07 or 3 73 on the tag. Post back when you find out. Jim ![]()
03 Sport |
#5 |
When is it enough?
You could go with D44's from NorthRidge 4x4 and be under $6K for both. As Otisdog said (and from what I've read on this Forum) the front D30 may not be that big of a concern, but If you are regearing, locker and upgrading the shafts in your D30 you could probably install a bolt in D44 yourself for the same price. Labor kills, it seams that the Labor usually matches close to the price of the items your installing. Not sure about the shipping.
5.5" RELA NorCAl Crawlers |
#6 | |
As others mentioned the D30 should hold up fine and not be a cause for concern unless you are doing something extreame.
OME ZJ/LJ combo | SwayLOC | 1.25" BL | Nth TT | Riddler diff covers | EMP gastank skid | 33" MTRs | Warn M8000 | Cobra75 and much more... Riddler torture test video Oil Filter Study Useful Axle Info Thread |
#7 | |
#8 | |
#9 |
Well I sure do appreciate it and I will keep you posted. And as to what the stock gears I have in... funny story, when I did my last differential servicing I am pretty sure I threw those things away without even looking at them.
#10 |
Its either 3.07 or 3.73. Since gears would be included in the price of the new axle, you might as well get different ones. 4.56 would be good for 33s, but you also have to regear the front too.
#11 |
Consider looking for used axles from a 2.5L. They are 4.10 ratio and will help. Then you could put an Aussie in the front.
#12 | |
#13 |
Yes I agree if I am going to change out the axle anyways wouldn't it just be more cost effective to swap both the front and rear with bolt on Dana 44's?
#14 | |
The D30 is much stronger than the D35. I have read some posts where guys are running the D30s locked with 37s and the stock shafts.
#15 | |
04 Unlimited RE SF 4.5", 1" MORE BL and MML, ARB Bull Bar, AR23 15x8, 35x12.5 MTRs, Jeep Medic Engine and T/F Skid, Shrockworks Rockers, Warn 9.5ti, AA SYE, ARBs, 4.88s and Alloy USA Shafts, HPD30 w JJs 1967 M416 www.midatlanticjeepers.com |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
