Axle swap time - JeepForum.com
post #1 of 2 Old 08-01-2010, 11:23 AM Thread Starter
blades012
Axle swap time
I found a set of stock axles (dana 30 and dana 35 ) with 4.10 gearing and only about 76,000 miles. I was wondering the average amount of time to swap both front and back axle. I am good with the 30 and 35 as it is my daily driver and do not wheel a ton. I also plan on not running anything bigger than 33 inch tires.
Because it is my DD, I am wondering a rough amount of time to swap them? I will be doing a spring lift at the same time.
Thanks
blades012 is offline
post #2 of 2 Old 08-01-2010, 11:27 AM
snowrydr01
Thanks
figure a long weekend. IF everything is perfect it could be done in a day, but inevitably youll have rusted bolts that slow you down and little things like that.
Last axle swap i did took an entire weekend because little stuff kept biting us, brake bleeders frozen and stripped out, control arm bolt frozen, ect. This was our third axle swap
snowrydr01 is offline
axle , swap , time , dana 30 , dana 35
Rubi swap / Axle swap (merged) tjmike TJ Wrangler Technical Forum 5 06-10-2010 02:04 PM
d30 yj to tj axle shaft or full axle swap? Rocky_Cosmark YJ Wrangler Technical Forum 3 02-14-2010 11:48 AM
Gathering parts for Axle swap, SOA, and V8 swap... tank29 YJ Wrangler Technical Forum 7 12-03-2009 03:42 AM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 04:28 PM
Axle Swap... I know I know one more time ;o) sebax TJ Wrangler Technical Forum 3 06-09-2005 05:33 PM
