Axle Swap Tech, Question About Drum Brake Assembly Removal - JeepForum.com
post #1 of 5 Old 01-10-2009, 01:06 PM Thread Starter
01TJfuntime
I picked up a set of 4.11 axles from a 1997 4 cylinder yesterday, cost was $360. The axles are in average shape clearly they will need brake work and some other miscellaneous stuff. My goal is to keep cost low so I will be using parts from my current dana 30/35 as I know many of these components have been well cared for and are in great working order.
I have never done my own brake work, so please forgive me if this is a stupid question. Last month I had my rear drums rebuilt. My questions is, is there any way I can completely remove the drum brake assembly, without tearing it apart, and swap it onto my new dana 35 axle?
01TJfuntime is offline
post #2 of 5 Old 01-10-2009, 01:29 PM
never monday
yes
undo the brake line. Then there are 4 buts that hold it to the axle housing
***WARNING***
you will need to bleed the brake system after this install
never monday is offline
post #3 of 5 Old 01-10-2009, 02:05 PM Thread Starter
01TJfuntime
This is what I figured, does anybody know what the torque specs are for those four bolts?
post #4 of 5 Old 01-10-2009, 02:10 PM
Jeepsr4me19
1976 CJ5
Even easier would be to pull the axle shaft and then unbolt the backing plate and let it hang. Then undue the brake lines from the axle so they hang free. Then put your new axle in and reinstall. No bleeding. You need to change fluid in rear anyhow so dump it and pull the axles. They are easy to remove. Just spin the carrier till you see a little bolt and remove it. Then slide out the cross pin. Then push in on the axles (near brakes) and remove the C-clips and then pull axles.
Jeepsr4me19 is offline
post #5 of 5 Old 01-10-2009, 02:35 PM
Coops
If you do not pull the brake lines off the cylinders it will be very tricky to get the backing plates off and out of the way to pull the axle. I'd also worry about bending the lines if you leave it all together. I undid the lines, tied the solid line from the axle to the frame and then tied the assembly forward with e-brakes still attached. You can try and use an open ended wrench to take the lines off but it probably won't work. I used a good set of vise grips to crack them loose and then used the wrench. Bleeding the brake lines is easy, you just need a friend.
Coops is offline
axle swap and brake caliper question driftbandito YJ Wrangler Technical Forum 15 11-01-2009 05:32 AM
TJ / Axle Swap & Brake Question Du510 TJ Wrangler Technical Forum 10 06-22-2009 11:25 AM
brake drum stuck on axle UTmike TJ Wrangler Technical Forum 10 12-14-2006 07:08 AM
drum brake removal chris06 TJ Wrangler Technical Forum 10 09-15-2004 12:14 PM
Rear brake drum removal Jeff Merkel YJ Wrangler Technical Forum 10 06-30-2002 09:10 PM
