Axle Swap - ?'s about compatibility d44 to d35 - JeepForum.com
post #1 of 10 Old 07-14-2012, 07:19 PM Thread Starter
S_nner
Okay I am having trouble finding a Dana 44 to swap out with my broke one. Found a Dana 35 for great price and I know without matching gearing I cant go into 4x4 and the dana 35 has disk breaks when I currently have drum breaks... will that be a problem or is that an easy issue when swapping out the axle's?
I also know that until I do find my Dana 44 LS that I wont be able to go off road cuz the dana 35 can't handle it... other than that is it okay if I down grade my dana 44 temporarily to a 35 ...? (daily driver and need it back up and running)
-- Matt
S_nner is offline
post #2 of 10 Old 07-15-2012, 01:34 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
What is wrong with your d44?
Wheelin98TJ is online now
post #3 of 10 Old 07-15-2012, 06:27 AM
gmiller0737
Did a search on car-part.com shows a 44 in your area 3.73 ratio for $990
www.car-part.com
gmiller0737 is offline
post #4 of 10 Old 07-15-2012, 06:34 AM
MainleyMud
Depends on a lot of other questions being answered as well. The Axle housing are different and may not fit your suspension. I'd fix the 44, you're probably going to be out less money and less frustration.
I always ask myself: Does it NEED to be said? Does it need to be said by ME? Does it need to be said by me RIGHT NOW? Then I log on to a forum and make an A$$ of myself! Getting old is great!
MainleyMud is offline
post #5 of 10 Old 07-15-2012, 07:09 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Mounting a TJ Dana 35 will be a straight swap. The Dana 35 E-brake cables should be compatible (if you have them) with your parking brake assembly.
Your Dana 44 driveshaft may be too short, as the Dana 44 has a longer snout.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #6 of 10 Old 07-15-2012, 08:06 AM
Irongrave
x2 on what did your break on the D44. just rebuild/fix it.
Current
2002 WJ 2wd DD
Irongrave is offline
post #7 of 10 Old 07-15-2012, 08:11 PM Thread Starter
S_nner
Both my ring and pinion broke a tooth off... so rebuilding it in my area is around 800 so I was looking into doing swaps instead because I can do swaps compared to the expertise needed for the rebuilding of the differential....
S_nner is offline
post #8 of 10 Old 07-15-2012, 08:18 PM
Irongrave
rebuild with better parts call it good, its a great time to regear it, and throw a locker in it
Current
2002 WJ 2wd DD
post #9 of 10 Old 07-16-2012, 12:18 PM Thread Starter
S_nner
Unfortunately I don't have the skill set or the tools ( micrometer) to do the rebuild or I would.... the rebuild will run me 800 to do it somewhere else with USA ring and pinion and bearing kit if I re-gear the back then I have to re-gear the front, correct? that would put my way over budget... now can I throw a locker into the d44 3.73 and if so what advantages does that give me and what would that run for the locker? ( I'm a total noob btw)
S_nner is offline
post #10 of 10 Old 07-16-2012, 12:56 PM
BigRodney
Are you kidding me! Phoenix is about 3 million people, there isn’t a junk yard with a D44 for sale? The ring and pinion and master install kit cost $400, if you can get someone to do it for $800 that’s $400 labor, not that much if they know what they’re doing, I’d just have it done. A D35 is a step backwards, I wouldn’t recommend it. Have you been to a wrecking yard and had them look for an axle for you in their computer? They have access to a lot of sources.
BigRodney is offline
axle , breaks , dana 35 , dana 44 , swap
Axle Compatibility? 98XJSport TJ Wrangler Technical Forum 2 10-31-2010 06:23 PM
axle rebuild compatibility kkchevy3 YJ Wrangler Technical Forum 1 09-08-2010 02:39 PM
Front axle compatibility sailmike83 YJ Wrangler Technical Forum 4 10-06-2009 04:30 PM
Axle compatibility Beachdrvr YJ Wrangler Technical Forum 1 09-30-2008 07:46 AM
81 Wagoneer Axle - TJ Compatibility imbezol TJ Wrangler Technical Forum 22 04-04-2008 10:54 PM
