Axle swap - JeepForum.com
post #1 of 4 Old 07-20-2010, 04:01 PM Thread Starter
stockstuck
Axle swap
so lets pretend i have very little mechanically. well we dont have to pretend. id like to do an axle swap from my stock dana 30's with 3.07 to something that would run 33's tires. i guess a dana 44 would work, right? is it possible to swap just the differential without swapping the entire axle? would that work?
what should i do to run 33's? I really dont wanna spend much. thanks.
new to this, ive been tryin to learn as much as possible.
stockstuck is offline
post #2 of 4 Old 07-20-2010, 04:19 PM
Heliparker
IMO dont wast your money one a D30. With that said you can regear the D30 you have now to run the 33's but you also would have to regear the rear. If you dont want to spend that much money find you a D30 from a junk yard with 410 gears and also pull the 410 gears out of the rear axle and install them in your rear axle . I choose to buy a bolt in D44 G2 axle that came with a tru track LS and 456 gears and had my rear D44 regeared to 456. That ran me about $2200. I saved to get what I wanted due to the fact of braking an axle in the D30. Good Luck!!
She is a Work in Progress!!
Heliparker is offline
post #3 of 4 Old 07-20-2010, 04:19 PM
03JeepX
well what you have will run 33's. I run that set-up myself. I have the auto I6 and it still has plenty of power.
EDIT: I shouldnt say plenty, I should say enough lol
03JeepX is offline
post #4 of 4 Old 07-20-2010, 04:56 PM
Heliparker
^^^^ this is true as well
axle , axle swap , differential swap
Rubi swap / Axle swap (merged) tjmike TJ Wrangler Technical Forum 5 06-10-2010 02:04 PM
d30 yj to tj axle shaft or full axle swap? Rocky_Cosmark YJ Wrangler Technical Forum 3 02-14-2010 11:48 AM
Gathering parts for Axle swap, SOA, and V8 swap... tank29 YJ Wrangler Technical Forum 7 12-03-2009 03:42 AM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 04:28 PM
Engine 4.3L swap and axle swap abrupt11 YJ Wrangler Technical Forum 14 02-18-2005 12:14 PM
