Axle Stub Shaft Interchange Between YJ and TJ - JeepForum.com
post #1 of 5 Old 09-25-2012, 06:05 PM Thread Starter
Karottop
Hi guys
I'm working on getting my jeep through inspection and I needed to replace my spindle. I have a dana 30 in the front, bone stock.
While taking off the hub assemble the axle shaft nut completely stripped off so the threads are screwed. I've got two questions.
1) how do I get the bearing assembly/housing off of the spindle. I've taken all of the bolts out and its not budging. Is it pressed on? Haynes manual says nothing about it. Tried prying with a screwdriver, tried a hammer. I'm not worried about breaking it because I have a replacement.
2) due to the stripped axle stub shaft I need another one. I got the spindle off of a grand Cherokee. I was wondering if the axle stub shafts were interchangeable between the YJ, Cherokees and grand Cherokees. Any advice will be a huge help.
Karottop is offline
post #2 of 5 Old 09-25-2012, 06:25 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
So your unit bearing is stuck to the knuckle? If so, here's how to get it free... http://www.stu-offroad.com/axle/unit...tbearing-1.htm
Here's the complete thing on replacing the entire inner/outer shaft.
http://www.stu-offroad.com/axle/d30/axle-1.htm
And how to install a one-piece D30 shaft into an older YJ D30 that came with two-piece shaft on the passenger side. http://www.stu-offroad.com/axle/yjd3...jconvert-1.htm
Gone on vacation until August 25.
Jerry Bransford is offline
post #3 of 5 Old 09-25-2012, 07:56 PM
ftgiles
And/or you can use just the outer shaft by removing the u-joint. All TJ/XJ/YJ use the same outers. But beware, there are different unit bearings and they can all work if they are matched with the correct offset brake rotor. So look into those details. Don't know any specifics on ZJ stuff or anti-lock type outers.
ftgiles is online now
post #4 of 5 Old 09-25-2012, 08:54 PM
MikeGordon
Are you sure about that? I thought only 95 YJ's used the 760/297 u-joints and earlier models used the 260's? Same with XJ's...but not sure when they made the switch...maybe '96?
MikeGordon is offline
post #5 of 5 Old 09-25-2012, 09:01 PM
ftgiles
Sorry, yes late '95 and newer for u-joint sizing. The lengths are the same.
assembly , axle , bearing , interchangable , shaft
Saginaw 800 steering box stub shaft troybrockman TJ Wrangler Technical Forum 4 09-07-2011 09:07 AM
Favorite front stub axle u-joints Krochus YJ Wrangler Technical Forum 7 02-08-2011 12:31 AM
Rubicon stub shaft same as a D30? dodgetk81 TJ Wrangler Technical Forum 2 06-08-2010 04:12 PM
Dana 30 Axle Shaft Interchange? JeepnBlake TJ Wrangler Technical Forum 3 01-10-2010 06:18 PM
Need to replace stub shaft for a 1999 BlackBellamy TJ Wrangler Technical Forum 2 03-23-2009 10:53 AM
