axle shaft touching pinion shaft - JeepForum.com
post #1 of 8 Old 08-21-2009, 10:51 PM Thread Starter
kit05
i did my axle seals today on my 35c noticed when trying to pull pinion shaft it was tight had to lightly tap it out, when i put it back together same thing had to tap it in a little, the passenger side axle has no end play,driver has play,can this be adjusted? not to familiar with gears, is there a shim behind the spider gear i could take out for more clearance? or is this normal , it drives fine, i guess it was like this when i bought it, thanks
kit05 is offline
post #2 of 8 Old 08-21-2009, 11:45 PM
fratis
fratis's Avatar
thats normal. for future reference please try to use the proper terms. sounds like you were referring to your differentials cross shaft.
fratis is offline
post #3 of 8 Old 08-21-2009, 11:58 PM Thread Starter
kit05
ok so its normal for my axle to be touching the pinion mate gear shaft on the passenger side, and my drivers side axle end play is with in tolerance for end play, wont my axle wear into the shaft? i thought both side needed some play in and out?and shouldnt the shaft slide out of the carrier when you remove the locknut, just want to make sure before i put the diff cover back on, im pretty sure the pinion mate gear shaft is the cross shaft
kit05 is offline
post #4 of 8 Old 08-22-2009, 01:19 AM
mudb8
want it rite or rite now?
mudb8's Avatar
Originally Posted by fratis View Post
for future reference please try to use the proper terms. .
he did....
make sure the c clip is seated. most take a gentle tap to remove.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #5 of 8 Old 08-22-2009, 08:39 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
He did, the pinion gears inside the differential are held in place with a pinion shaft.
Look up pinion gears and you'll understand.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #6 of 8 Old 08-22-2009, 10:28 AM
Stu Olson
Stu Olson's Avatar
When I had a whopping 18 posts under my belt, I'm glad someone didn't jump into the middle of one of my posts and tell me to use the proper terms.
There is such a thing as a learning curve.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Stu Olson is offline
post #7 of 8 Old 08-22-2009, 12:30 PM Thread Starter
kit05
i prefer to search and read then post, im not new to jeeps, just new to dipping into the rearend, so should the axle be a little tight to the pinion shaft?
kit05 is offline
post #8 of 8 Old 08-22-2009, 12:42 PM
fratis
fratis's Avatar
wow echo echo.
sorry i was a little confused. i do apologize. i do have differential experience and have been working with them for years. again kit05 what you describe sounds fine and is normal.
anyone else want to bash me? i deserve it let it rip!
fratis is offline
D44 & D35 Pinion shaft lengths Duck Dodgers TJ Wrangler Technical Forum 3 04-23-2009 08:33 AM
Pinion shaft nut Robbypfd YJ Wrangler Technical Forum 2 01-10-2008 06:19 PM
D35 pinion shaft screw??? k1llerkyle YJ Wrangler Technical Forum 11 07-02-2007 08:50 PM
pinion shaft and inner axle seal on D30 snakehunter TJ Wrangler Technical Forum 1 06-14-2007 05:44 AM
Pinion angle for cv shaft dodgetk81 TJ Wrangler Technical Forum 1 04-08-2007 10:39 AM
