> Models
> Jeep Wrangler Forums
> TJ Wrangler Technical Forum
Axle seal , wheel seal whats it called???
05-21-2009, 09:42 PM
#1
What is the flange looking piece of metal that is pressed onto the front stub axle of a dana 30 on a 2005 TJ that rides against the wheel bearinf assembly? Also I asume it should be true and not distorted in shape?? Need one and auto parts stores are no help, even with part in hand???
05-21-2009, 09:46 PM
#2
They're typically referred to as "slingers".
I am Savvy
blackmagicbrakes.com
05-22-2009, 04:42 AM
#3
AFSOC Retired
And its made out of plastic...
05-22-2009, 05:38 AM
#4
the ones i have seen are metal , i have just pounded them back to a flat lip and reused them
05-22-2009, 05:56 AM
#5
The slinger is on the axle tube of the inner axle and is plastic. This is metal and lives on the outer (stub) axle.
05-22-2009, 06:02 AM
#6
Got a picture?
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad
I drive on the right side, what's wrong with you?
Be very careful with the wife mod. Uninstallation can be extremely expensive. Wife mods have been known to take the Jeep and all other mods during the uninstall process. Also, make sure you service your wife mod properly as often as humanly possible. Wife mods not properly serviced may malfunction or uninstall themselves at any time.
05-22-2009, 08:20 AM
#7
Originally Posted by les.delancy
Got a picture?
You'd think they would know better by now-
https://www.solidaxle.com/PDF/tech_s...ly%20Front.pdf
Part number 37308 as an example.
I am Savvy
05-22-2009, 08:30 AM
#8
Ok OP, there you go. I never did figure out which part you were trying to describe, but they are all given names in that diagram...
05-22-2009, 08:39 AM
#9
Here you go...
1 - SHAFT, Axle
04874303 1 J [BGA], Left
04874306 1 J [BGK], Right
04874307 1 J [BGK], Left
1 J [BGA], Right
05083666AA 1 J [DJC], Right
05083667AA 1 J [DJC], Left
2 - SHAFT, Stub
83500184 1 J [BGA] Without [DJC], Right or Left
04728984 1 J [BGK] Without [DJC], Right or Left
1 U 77 [BGK] Without [DJC], Right or Left
1 U 77 [BGA] Without [DJC], Right or Left
3 - U JOINT, Front Axle
05083670AA 1 J [DJC] Only, Right or Left
04137757 1 U 77 , Right or Left
1 J Right or Left
4 - SLINGER, Oil
04882135 2 U 77
2 J
05083669AA 2 J [DJC] Only
5 - 68002412AA 2 J GUIDE, Axle Shaft, [DJC] Only
Note:Sales Codes;
Note: There is no stub shaft for the DJC axle.
[BGA]=Brakes - Power Front Disc/Rear Drum
[BGK]=Brakes - 4-Wheel Anti-lock
[BRW]=Brakes - 4-Wheel Disc[/left]
[DJC]=Axle -Front, Heavy Duty Dana M44/216M
[CENTER][SIZE="5"][COLOR="DarkRed"][B]DON'T FEAR THE RE-GEAR!!![/B][/COLOR][/SIZE]
[CENTER][B][COLOR="DarkRed"][SIZE="3"]______[/SIZE]
[SIZE="3"]|_____|[/SIZE]
[SIZE="2"](O|||||||O)[/SIZE]
[SIZE="1"]|______|[/SIZE][/B][/COLOR]
[SIZE="5"][][/SIZE]===[SIZE="5"]o[/SIZE]==[SIZE="5"][][/SIZE][/CENTER]
[SIZE="4"][COLOR="DarkRed"][B]RED JEEP CLUB MEMBER #430[/B][/COLOR][/SIZE][/CENTER]
05-22-2009, 01:00 PM
#10
Its in the diagram above reference number 2, not the Stub shaft but the other piece. Whats it called?
05-22-2009, 01:18 PM
#11
I've already told you, posted a link to an exploded view that shows the part and calls it out by it's correct name and you still have to ask?
I am Savvy
05-22-2009, 01:20 PM
#12
Here, does this help at all?
Stub Shaft Slinger
I am Savvy
05-22-2009, 01:21 PM
#13
05-22-2009, 01:56 PM
#14
What it's showing is, name (slinger) aside, it's not available as a separate part. It's ordered with the stub shaft.
05-22-2009, 03:22 PM
#15
You can get one here $3.99 http://www.4wd.com/productdetails.aspx?partID=6825
Alternatively, PM your name and address and I will send you one, new in the box no charge
