Axle RTV Remover - JeepForum.com
post #1 of 5 Old 08-17-2004, 06:30 AM Thread Starter
SpitNine
2015 JK Wrangler
Axle RTV Remover
I changed the oil in the rear differential and was scraping off the old RTV. Once I got the big chunks off with a razor blade scraper I used on of those grey paint remover pads from 3M (they look like the green scouring pads for pots but much more coarse) to get the rest of the RTV off. It worked great and fast.
BTW, I experimented with using just a gasket coated both sides with grease instead of RTV. So far, since last Saturday, no leaks and I did a two hour, 70mph run down the Interstate since then.
Got the gasket/grease tip from another poster here a few weeks ago.
Thanks.
2015 Sport
Six Speed
Hardtop
Fire Cracker Red
SpitNine is offline
post #2 of 5 Old 08-17-2004, 08:02 AM
wyldejackyl
You use scotchbrite, I use 600 grit sandpaper with alcohol as a cutting lube. Either way, that RTV crap is coming off!
..::2007 JK Unlimited X::..
1500W inverter
Midland 1001LWX CB
55/100W H4 Hella headlamp conversion w/ dual relays
wyldejackyl is offline
post #3 of 5 Old 08-17-2004, 08:56 AM
skifast1
skifast1's Avatar
Tip: wear mechanic's gloves when scouring the RTV off. The inside edge of the sealing surface is really sharp and can slice your finger when you're scouring.
skifast1 is offline
post #4 of 5 Old 08-18-2004, 03:45 AM
Oman Jeep
Oman Jeep's Avatar
Sounds like something learned from experience! Hope you weren't cut up too badly!
Oman Jeep is offline
post #5 of 5 Old 08-18-2004, 07:36 AM
skifast1
skifast1's Avatar
Just bad enough to convince me to invest in a good pair of gloves! Besides, now me and my TJ are 'blood brothers'
skifast1 is offline
Best Decal Remover? krutj JK Wrangler Technical Forum 11 01-09-2010 08:20 PM
Suggestions please - grime remover toomanyjeeps YJ Wrangler Technical Forum 24 10-10-2007 10:15 PM
Dealer Sticker Remover Help StevieO40oz TJ Wrangler Technical Forum 20 08-31-2007 05:51 AM
Window Scratch Remover stedwest TJ Wrangler Technical Forum 12 12-04-2006 08:39 PM
Scratch Remover mletschin YJ Wrangler Technical Forum 4 03-17-2004 08:52 PM
