axle ratio question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > axle ratio question
20 Ton Press Brake DIY Builder Kit @ Swag Off RoadFenders for your Jeep at Jeephut.comSave on Selected Skyjacker Shocks!
Unread 08-21-2013, 05:10 PM   #1
punkxiao
axle ratio question
had a accident then damaged the front axle
i read about the the stock tj specs here
kinda confused about the axle ratio
if it doesnt fit my Jeep axle ratio
how it can be changed? or it is not switchable?
found a couple of used front axle on ebay
http://www.ebay.com/itm/151102270018...84.m1423.l2649
http://www.ebay.com/itm/161014881479...84.m1423.l2649
also for the radiator
is this one factory model?
http://www.ebay.com/itm/281154429402...84.m1423.l2649
or compare to
http://www.ebay.com/itm/290669342017...84.m1423.l2649
which one do you guys suggest?
or is there cheaper one?
thanks a lot for reading this
punkxiao is offline   Reply With Quote Quick reply to this message
Unread 08-21-2013, 05:26 PM   #2
MotoSoul
MotoSoul's Avatar
Gears can be changed in any axle you pick up. Just be warned that doing that will cost you a couple hundred dollars. Check your jeep for tags on the diff covers to see what you have. If you need one with 3.73 gears I might know of one that would work for you.
I like the arms, they are a good solution, but they really aren't worth the effort for the average person and you already see the BS that goes on over bushings VS JJ's, the crap that would go on over J arms would be epic.
MotoSoul is offline   Reply With Quote Quick reply to this message
Unread 08-21-2013, 05:34 PM   #3
punkxiao
thx buddy
i will check it asap
and you are close to me
also my jeep is 03 tj AT 4.0L i6
they have different ratio for same year model?
Unread 08-21-2013, 05:35 PM   #4
sjones26573
Yes
The Yellowtail Build
Originally Posted by Jeremy Clarkson - Top Gear Botswana Special
Why don't all cars have no doors? When I come to power I'm going to make it a rule because this is just better.
sjones26573 is offline   Reply With Quote Quick reply to this message
Unread 08-21-2013, 06:33 PM   #5
TJDaveX
Tater Salad
TJDaveX's Avatar
Your 03 TJ with the 4sp OD automatic 42rle tranny will have 3.73 gears from the factory.
Unless it's a Rubicon...4.11
TJDaveX is offline   Reply With Quote Quick reply to this message
