axle question. Dana 30 front and 8.8 rear - JeepForum.com
post #1 of 11 Old 08-24-2012, 04:45 PM Thread Starter
Jachi101
just finished up with my 3" lift from zone. Awesome! Right now I have dana30 up front and the 35 in the rear with 31"s. The goal is to be running 33"s.
After doing some reading I and wanting to find a 8.8 with some 4.10's already in it and just regear the stock dana 30 to match. This is my first time switching axles or anything like this, so basically I want to know if this will work? And if iam overlooking anything? I am on a budget and do not need top on the line. Mainly an on road during the week but want to be able to take if offroading and not have to worry about anything breaking. Thank you
Jachi101 is offline
post #2 of 11 Old 08-24-2012, 05:33 PM
freeskier93
I wouldn't run an 8.8 if 33s are going to be your max tire size.
freeskier93 is online now
post #3 of 11 Old 08-24-2012, 06:12 PM
DBibeau855
I agree. An 8.8 is best suited for 35s and larger. Either get a D44 or an S35 kit. I run the 30 spline c clip eliminator kit with an Ox locker and I love it.
55w 6000 DDM HIDs. 130 Watt KC daylighters(X4). AA SYE, Tom Woods CV drive shaft, currie upper rear control arms and 33X12.5 KM2s. Rubicon Express 3.5 inch lift. Supperior D35 30 Spline C clip eliminator, Ox locker, 4.88 gears. HP D30 W/ detroit locker w/ currie adjustable arms. Currie front Anti Rock. Adjustable front and rear track bars,
DBibeau855 is offline
post #4 of 11 Old 08-24-2012, 09:01 PM Thread Starter
Jachi101
Sorry. Should have mentioned that I do want 35's down the road.
From what I have seen on the forum an 8.8 is a lot easier to find used and also cheaper then an d44. What is wrong with an 8.8 on 33's?
Jachi101 is offline
post #5 of 11 Old 08-24-2012, 09:01 PM
freeskier93
The pumpkin hangs low. If your thinking about 35s then an 8.8 is a good option. Consider skipping 33s, build for 35s then make the jump.
post #6 of 11 Old 08-24-2012, 11:04 PM
FarmerinVA
Being "on a budget" but planning to build for both 33s and then shortly later 35s? Not compatible. I personally wouldn't go for 35s unless there was a really pressing trail need but if you do want them, you will save a boatload of money skipping the intermediate step.
My do-it-yourself install thread for a TrueTrac in the rear, upgraded shafts, and a PowerTrax No-Slip in the front:
FarmerinVA is offline
post #7 of 11 Old 08-25-2012, 08:55 AM Thread Starter
Jachi101
Alright thanks guys. Appreciate the input! I am wondering though with the pumpkin haning "low" with 33's. Is that more of an issue when rockcrawling or offroading. How does it do on road? And also how low does it actually hang? Would I be fine with wild offroading. Thanks again for help. Asking because I have seen a few on here running an 8.8 with 33's and never heard of this clearence issue.
Jachi101 is offline
post #8 of 11 Old 08-26-2012, 06:05 PM Thread Starter
Jachi101
Been doing some reading today and have decided to just up to 35's and getting the 8.8 with 4.88 gears. Is a 3" enough height to run 35's or should I start looking for a body lift too. Thanks
Jachi101 is offline
post #9 of 11 Old 08-26-2012, 08:59 PM
MattJeep
2003 WJ
The pumpkin hanging low will probably be fine for you. You really have to build to the type of wheeling your gonna be doing. Mild offroading in construction sites is easily doable with the Dana 35, unless your trying to break it. Realistically decide what kind of wheeling your gonna do, if any, and then build around it.
MattJeep is offline
post #10 of 11 Old 08-27-2012, 12:12 PM
biffgnar
biffgnar's Avatar
If you try to stick to 3" better invest in some significant bumpstop extensions.
Romney in 2020!
biffgnar is offline
post #11 of 11 Old 08-28-2012, 08:35 AM
geiman
I'll agree with the 8.8 and 33s resulting in a very low hanging diff. It's not exactly terrible, but it is quite annoying. I put my 8.8 in about a month ago, and I plan on getting 35s ASAP but in the meantime I'm stuck on 33s. My last trip to Rausch I was dragging quite a bit in the rocks. Elsewhere it doesn't really matter, but in the rocks I was very aware of it. I was thinking about shaving it a bit anyway because the 8.8 is just so big, but I think the rocks might do it for me before I get a chance.
If you can afford it, go ahead a build for 35s now.
geiman is offline
75-77 F150 Dana 44 front axle question 93YJfalcon YJ Wrangler Technical Forum 21 02-14-2013 03:07 PM
TJ Dana 35 rear axle question. Fflintstone TJ Wrangler Technical Forum 3 04-28-2012 09:20 PM
99 SE 2.5 dana 30 front axle question JeepJeep31 TJ Wrangler Technical Forum 1 10-04-2009 07:45 PM
Question about Dana-30 Front Axle Protoxis YJ Wrangler Technical Forum 8 08-03-2009 06:31 PM
QUESTION: front axle(DANA 30) why does mine look like a DANA 35 713JeepTJ TJ Wrangler Technical Forum 5 03-06-2005 09:20 PM
