Axle Question (D30) - JeepForum.com
post #1 of 10 Old 08-03-2010, 03:45 PM Thread Starter
alex_c
Axle Question (D30)
I'm looking at an HP d30 with 4.56, 30 spline chromos and an ARB. Could I swap these parts into a LP TJ D30 with 4.10 gears? Basically what I'm asking is if the locker is the same for the LP as it is for the HP. Seems like a silly thing to do, I know, but I'm not sure if I can afford to get my 8.8 re-geared to match. Also, could I swap the carrier and shafts from the low pinion TJ axle and put them in the high pinion XJ axle? I could sell that and get some cash back potentially.
alex_c is offline
post #2 of 10 Old 08-03-2010, 03:50 PM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
you can swap everything but the r/p.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #3 of 10 Old 08-03-2010, 03:54 PM Thread Starter
alex_c
Good to know, thanks.
alex_c is offline
post #4 of 10 Old 08-03-2010, 04:08 PM Thread Starter
alex_c
Another Question, is $700 (CAD) a good deal for an HP d30 with 30 spline shafts, ARB and 4.56 gears? It has the vacuum disconnect eliminator...will these shafts still work in a TJ housing?
alex_c is offline
post #5 of 10 Old 08-03-2010, 04:49 PM
jeepinmichguy_
Soar Forever Six
as long as everything is good on the axle i would pay that. yes, again everything but the r/p will swap over. if it has 30 spline outers you will need new unit bearings.
ΜΟΛΩΝ ΛΑΒΕ
post #6 of 10 Old 08-03-2010, 04:51 PM Thread Starter
alex_c
Can't I just use the existing unit bearings in the axle, in the TJ housing?
alex_c is offline
post #7 of 10 Old 08-03-2010, 05:40 PM
jeepinmichguy_
Soar Forever Six
if it has them.
ΜΟΛΩΝ ΛΑΒΕ
post #8 of 10 Old 08-03-2010, 05:42 PM Thread Starter
alex_c
I'm pretty sure it's a complete assembly with knuckles and brakes.
alex_c is offline
post #9 of 10 Old 08-03-2010, 05:50 PM
Apex
Recon death squad
Apex's Avatar
You do know if you swap the ARB over to your LP30 you will have to set up the gears again...
Apex is offline
post #10 of 10 Old 08-03-2010, 05:52 PM Thread Starter
alex_c
The ARB will change the backlash/pinion depth?
alex_c is offline
arb , locker , d30 , dana 30 , hp , lp , high pinion , low pinion , swap
8.8 axle and stock axle question YJTJlover YJ Wrangler Technical Forum 7 03-01-2012 05:48 AM
D35 axle question rip_1986 YJ Wrangler Technical Forum 8 03-18-2009 11:14 AM
New axle question??? flyerboy1522 YJ Wrangler Technical Forum 3 05-08-2008 08:59 AM
07 JK axle question MetZenDS JK Wrangler Technical Forum 17 12-17-2007 05:53 PM
Tire/Rear Axle question....out of alignment, rear axle "turned". (Thrust Angle) Sparty TJ Wrangler Technical Forum 5 09-19-2007 02:23 PM
