Axle Product Question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Axle Product Question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineToxic Brakes - 3000 PSI Braided Stainless Steel Brake LineCess Recovery Gear Snatch Tow Strap OffRoad @ ROCKRIDGE4WD
Unread 03-15-2014, 08:49 AM   #1
mrblaine
Wizard of Brakes
mrblaine's Avatar
How many folks would be interested in front axles for the Jeep TJ that fit the larger JK u-joint into them?
Inners would be the common 27 and 30 spline, heat treated 4340, and 27 spline outer stubs that fit the stock unitbearings.
If the pricing was similar to current high quality offerings, who would want some?
The axle kit would require no changes to anything except perhaps slightly smaller flanges on the unitbearing bolts.
I am Savvy
blackmagicbrakes.com
mrblaine is offline   Reply With Quote
Unread 03-15-2014, 09:10 AM   #2
biffgnar
biffgnar's Avatar
How about 31 spline inners? Probably not much demand for them as most probably running more serious outers already.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote
Unread 03-15-2014, 09:38 AM   #3
Line58
That sounds interesting.
[URL="http://whateversclever.userboard.net/"]http://whateversclever.userboard.net/]Whatevers Clever Forum[/URL]
[URL="http://www.jeepforum.com/forum/f9/ax5-ax15-swap-write-up-murphys-law-edition-1515070/"]TJ AX5 to YJ AX15 Swap[/url]
Line58 is offline   Reply With Quote
Unread 03-15-2014, 09:48 AM   #4
holdren4100@cyb
Who wouldn't want the bigger u-joints.
holdren4100@cyb is offline   Reply With Quote
Unread 03-15-2014, 10:42 AM   #5
crateampscal
I would. Last time we went out, 3 out of the 6 guys popped that ujoint. I was one of em and if it would help that, i know a few local guys interested too.
crateampscal is offline   Reply With Quote
Unread 03-15-2014, 10:46 AM   #6
hustler905
I would purchase such a product if I didn't already have alloy front axles. Are the JK u-joints much more expensive to replace than a 760x?
hustler905 is offline   Reply With Quote
Unread 03-15-2014, 11:17 AM   #7
pcoplin
I didn't think the 1350 was much of an upgrade over the 760?
98 TJ 5.9/46RE/D300
85 Wagoneer 5.2/44RE
01 F250 Powerstroke 7.3/ZF6
Ultra4 KOH #689 car
pcoplin is offline   Reply With Quote
Unread 03-15-2014, 11:26 AM   #8
Ljcrawler05
I would be update with the cost
Ljcrawler05 is offline   Reply With Quote
Unread 03-15-2014, 12:00 PM   #9
mrblaine
Wizard of Brakes
mrblaine's Avatar
The heavier JK's typically run 37's on them with few issues. It is an upgrade and an easy way to get some more strength in the common weak link.
I am Savvy
Unread 03-15-2014, 12:01 PM   #10
mrblaine
Wizard of Brakes
mrblaine's Avatar
It doesn't matter if they are more expensive because a u-joint break rarely leaves both axles intact. But yes, they are more expensive by double.
I am Savvy
Unread 03-15-2014, 12:04 PM   #11
mrblaine
Wizard of Brakes
mrblaine's Avatar
I've quit trying to guess what folks are interested in or would spend money on. I've been wrong so many times when it comes to figuring that out I don't even try any more, I just ask.
To me if the price is comparable to a set of quality alloy axles with the only difference being the u-joint cost, like you said, who wouldn't want them?
Seems like a no brainer to me, but what do I know?
I am Savvy
Unread 03-15-2014, 12:08 PM   #12
robncar
We Got The Cup, AGAIN!!!
robncar's Avatar
What about a set of CTM JK joints too? I would think that folks that were in the market for new axles would want in on this. I know I would have been when I bought my 30 splines.
robncar is offline   Reply With Quote
Unread 03-15-2014, 12:09 PM   #13
geiman
I would be extremely interested. I haven't bought any "upgraded" shafts for the front yet, though I've been looking at getting something in the very near future.
geiman is offline   Reply With Quote
Unread 03-15-2014, 12:10 PM   #14
Varnish
Varnish's Avatar
So the axleshafts wouldn't be available off the shelf if you did break a ujoint?
'98 TJ (see profile)
'88 YJ with 4.0/AW4 swap & CJ front end
'80s CJ Resto-mod ('80s CJ frame/front end, YJ tub, '00 XJ 4.0)
'99 XJ 4dr SE
Varnish is offline   Reply With Quote
Unread 03-15-2014, 12:36 PM   #15
RockMonster
I see u joints as diriveline fuses. I would rather pop a cheep joint than somthing else; im not sure if it would be a great idea on the 30.
God... my spelling sux.... +++++++++++++++++++++++OIIIIO+++++++++++++++++++++++++
RockMonster is offline   Reply With Quote
