Axle pics what do you think? - JeepForum.com
post #1 of 22 Old 07-28-2010, 12:03 PM Thread Starter
lemonsigmapi
I bought a Jeep that needs some work. If I drive more than 20 miles or so, I hear popping coming from the front end. I took it to a joker who told me to get a whole new axle and lower control arms. It is not leaking and it drives straight as an arrow. Do you think I could replace the control arms, mounting brackets and knuckle and be fine? I really dont want to put a junkyard axle in it.
lemonsigmapi is offline
post #2 of 22 Old 07-28-2010, 12:10 PM
mdm
Farm Wheeler
When do you hear the noise?
Going straight?
Turning?
Bumps?
Low speed/high speed?
Braking?
Accelerating?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 22 Old 07-28-2010, 12:13 PM
04_Sahara_Man
Sure its not the transfer case linkage hitting the tub?
Currently 04 Sahara: 3" BDS lift, 9500 BDS Monotubes, Flowmaster Super 44, Olympic Rocker Guards, 33" Duratracs, 15x8 Black Rock Blades.
Khaki Jeep Club Member
In Pennsylvania, fun is illegal
Xbox live GT - TheExecutive00
Tama, Paiste, DW, Zildjian, Vic Firth....yes I go boom boom!
04_Sahara_Man is offline
post #4 of 22 Old 07-28-2010, 12:15 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
i could be wrong, but i think it has something to do with that lower control arm mount [pictured].
you can buy some LCA mounts from rusty's or other places that are beefier than the stock mounts. of course, the old need to be removed and the new welded in place.
Mail crawling.
MisfitSeven is offline
post #5 of 22 Old 07-28-2010, 12:17 PM
gabriel05
You might be able to get away with just new brackets.
9706LCABK Lower Control Arm Bracket
Front the pics it looks like the whole axle is shifted slightly to the pass. side of the jeep. The spring looks a little crooked compared to the bump stop, it could just be the angle of the pic though. Also the tie rod looks like there is a bit of a bend to it, again this might just be the angle of the picture. How did this happen? Id start looking over everything very carefully and see if there is anything else out of whack.
Black Jeep Society Member
gabriel05 is offline
post #6 of 22 Old 07-28-2010, 12:21 PM
little_Jeep
Your lower control arm brackets are toast, but that isn't what is making your popping noise. RUSTY'S sells some nice replacement lower control arm brackets for about $60.00..... you will need to cut the old OEM junk off (not hard to do) and weld the new ones on.
little_Jeep is offline
post #7 of 22 Old 07-28-2010, 12:22 PM
04_Sahara_Man
oooh yea didnt see that bracket...yea def need new ones
post #8 of 22 Old 07-28-2010, 12:24 PM
mdm
Farm Wheeler
Photos were too big for me to see well. But yeah, they've been beaten pretty badly.
mdm is offline
post #9 of 22 Old 07-28-2010, 12:46 PM Thread Starter
lemonsigmapi
It makes it when turning at low speeds after alot of driving. It doesnt make any noise when I first get in it if I want to figure 8's even. I really have no clue how it happened.
post #10 of 22 Old 07-28-2010, 12:47 PM
04_Sahara_Man
the PO beat it thats what happened
post #11 of 22 Old 07-28-2010, 01:07 PM
pile_alcalineNJ
yeah dude seems your lower control arm mounts are shot, check for other warped metal and replace it
Where did i put my doors?
pile_alcalineNJ is offline
post #12 of 22 Old 07-28-2010, 01:11 PM
04_Sahara_Man
put a level on the axles..make sure their not warped either.
post #13 of 22 Old 07-28-2010, 01:48 PM
mikevsgeek
I would check your axle shaft ujoints since you say its happening while turning. It possible that the seal has gone bad and the heat from driving would be creating friction and giving you noises while turning.
I would also check the oil in your differential. If the PO put the wrong type of oil in, you might not be getting the lubrication that you need at higher temps.
mikevsgeek is offline
post #14 of 22 Old 07-28-2010, 02:09 PM
krelja
x2 popping when turning usually leads to u-joints. It could be a bunch of different things since the jeep looks beat to all hell. Fix the stuff that is visibly wrong and then start tracking down other stuff. I would recommend picking a front axle from a u-pull it and putting it in. It should be fairly cheap and plenty of spare parts for your beaten down D30
krelja is offline
post #15 of 22 Old 07-28-2010, 07:53 PM
04_Sahara_Man
Prob alot cheaper too then a shop pulling the axle and putting it in a jig and welding on the new brackets.
axle , control arms , replace , advice , help
Axle leak with pics Poke YJ Wrangler Technical Forum 16 06-24-2008 07:44 PM
Axle swap almost done; but.. Pics Swampwalker3 YJ Wrangler Technical Forum 18 11-05-2007 10:41 PM
Axle question (pics) island hopper TJ Wrangler Technical Forum 6 10-17-2007 11:50 AM
axle pics jim_bert TJ Wrangler Technical Forum 11 08-22-2007 09:19 PM
looking for some spring over axle pics!! Git-R-Done YJ Wrangler Technical Forum 21 08-09-2006 03:18 PM
