Axle not centered - JeepForum.com
post #1 of 17 Old 08-04-2010, 08:16 PM Thread Starter
Ulumanati
Axle not centered
Okay so it seem my axle sticks out further on the drivers side more than the passenger and while I do know that it's a trackbar issue, my Nth suspension already comes with a specific front trackbar relocator and I have already isconnected it an shook the vehicle, then reconnected but it's still somewhat shifted.
You can see the springs being pulled more towards drivers side like bowed from the sides. What could be the answer?
2004 Silver Jeep Rubicon
6" Nth Degree Longarm Kit
Ulumanati is offline
post #2 of 17 Old 08-04-2010, 08:27 PM
lumpster
lumpster's Avatar
adjust the trackbar, if its not adjustable buy one that is.
lock thread.....
lumpster is offline
post #3 of 17 Old 08-04-2010, 09:00 PM Thread Starter
Ulumanati
lock thread.....
Right.. I know to adjust trackbar but the thing is you shouldn't need one with this Nth suspension. It came with a WJ trackbar supplied and the drop down brackets and everything so I would think it would line up.
I just wanted to know if any Nth users had any experience with this.
post #4 of 17 Old 08-04-2010, 10:30 PM
MFortie
MFortie's Avatar
My Nth front track bar kit has an adjustable drop to 'help' center the axle based on lift height. I need to move mine over just a bit as well. AEV's install guide basically says centering the axle is a 'best effort' task and you shouldn't really expect the axle to be perfectly centered.
Here's a link to their install guides -- read the install doc and you'll see for yourself. American Expedition Vehicles - Product Documents
MFortie is offline
post #5 of 17 Old 08-04-2010, 10:39 PM
JeepnBlake
That's craptastic... I don't very much like their description at all.. Basically a you lifted it, prepare for no handling.
Anyway to help out the OP if your axle is too far out the drivers side, and not far enough under the passenger side, you track bar is too short.
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #6 of 17 Old 08-04-2010, 11:34 PM Thread Starter
Ulumanati
Thanks for the tip, lol it's strange that Nth supensions being so "above" everything else and expensive, you'd think it wouldn't just be a best effort but I guess no one suspension is perfect. I'll be sure to look it over tho.
What are the drawbacks to the axle not being centered? Mine is not off by too much so mAybe I'm just being paranoid. It doesn't seem to drive weird or anything, but will it wear anything out more?
You can tell the control arms and springs are tilting more toward the drivers side so it must be somewhat significant.. I'm just scared when I reinstall my front driveshaft, that it won't be lined up from TC to diff and maybe bind the ujoints.
post #7 of 17 Old 08-05-2010, 12:01 AM
JeepnBlake
Well if you're OCD it's going to bug the crap out of you like it bugged me. That's all I got, its doubtful it's off far enough that your steering will be off, but maybe it is, who knows.
-Blake-
Build Thread:
Dad's Build Thread:
post #8 of 17 Old 08-05-2010, 12:32 AM
lumpster
lumpster's Avatar
there are alot of jeeps out there on 2 inch BB that havent done anything about track bars front or rear, they drive fine. Its mostly a look thing, OCD thing(i fall in this catagory), or a clearance thing.
lumpster is offline
post #9 of 17 Old 08-05-2010, 12:39 AM
R0cket
1930 TJ Wrangler
i had to have my lineman sized roommate push my jeep over while i installed my track bar.... i had him slam into it and i eyeballed where it came to and adjusted the trackbar to that then did little adjustments while he pushed with all his weight to line it up.... mine is now lined up perfectly.
Ian
AME2 USN, Disabled Vet
R0cket is offline
post #10 of 17 Old 08-05-2010, 12:55 PM
MFortie
MFortie's Avatar
Well, I guess you just hafta drive one...
Mine is the best handling Jeep I've ever driven -- not that I've driven more than a dozen or so different Jeeps. I pulled off a RE 3.5" full kit to install the AEV/Nth. No comparison. I installed the RE kit on my buddy's 2000 TJ for him and drove it before and after for comparison as well.
Not sure what you're referring to with handling anyway -- the axle will shift side to side in relation to the frame as the suspension compresses/extends because of the nature of a track bar setup. I'm more concerned that at full stuff my bumpstops are actually being used for their intended purpose than whether my axle is sitting 'pretty' at a standstill (on a level surface, with no additional weight in the Jeep, yadda, yadda, yadda.)
If your thrust angles are good, it shouldn't make a heck of a lot of difference if your axles are perfectly in line. My rear thrust angle is still out by 5/8" (yeah, I still need to get around to remedying that) and it still drives beautifully!
YMMV
Mark
MFortie is offline
post #11 of 17 Old 08-05-2010, 01:58 PM
JeepnBlake
YMMV
Mark
Not saying it doesn't drive nicely, I'm just saying since AEV/Nth makes such a big deal about lift and "high" speed handling it just strikes me as kind of bizarre that they say it's a "make the best of" when it comes to track bars is all.
-Blake-
Build Thread:
Dad's Build Thread:
post #12 of 17 Old 08-05-2010, 04:35 PM
crgrissom
Master of Reality
crgrissom's Avatar
That's about the best way to get the rear one done, but for the front, the easy thing to do is get the wheels straight, then disconnect the trackbar at the axle end, and use the steering wheel to get the axle to the desired left-right position. Then adjust the trackbar accordingly and bolt it in. You'll have to recenter your steering wheel, of course.
That's assuming you have an adjustable front trackbar.
Chuck
Chuck Grissom
Opportunity is missed by most people because it is dressed in overalls and looks like work.
- Thomas A. Edison
crgrissom is offline
post #13 of 17 Old 08-05-2010, 04:48 PM
R0cket
1930 TJ Wrangler
Chuck
i probably should've said that... but yes, that's what i did... muscle the rear, and use the steering wheel for front
Ian
R0cket is offline
post #14 of 17 Old 08-08-2010, 06:51 AM
James Chang
What do I need to center
I am planning to put on 2" BB. Someone just told me that it will make something off centered with this lift. Is it true? If yes, what parts do I need to correct this problem?
Also, do I need longer sway bars?
Thanks!!!
James Chang is offline
post #15 of 17 Old 08-08-2010, 06:52 AM
James Chang
Sorry, meant to start a new thread, followed this one by mistake
axle , centered , center , trac bar , track bar , relocation , tj , wrangler
Front Axle & Rear Axle is off centered to the passenbe off centered by .5" pass side? Lemmiwinks TJ Wrangler Technical Forum 4 07-09-2009 05:46 AM
Should the Front Axle & Rear Axle be off centered to the passanger side by .5"? Lemmiwinks TJ Wrangler Technical Forum 3 07-07-2009 09:27 AM
centered axle? LovinFirstJeep JK Wrangler Technical Forum 4 05-08-2009 03:27 PM
axle not centered Maverick14 TJ Wrangler Technical Forum 8 04-05-2008 09:12 PM
Axle not centered? Maverick14 TJ Wrangler Technical Forum 7 01-16-2008 05:55 PM
