Axle help - JeepForum.com
post #1 of 12 Old 02-02-2011, 11:04 AM Thread Starter
Logant
Axle help
I have a 97 Tj sport with a Dana 44 rear and a 30 up front.. Just wondering if that is a good/rare combo cause I don't see a whole lot on here, thanks! Any info is appreciated
Logant is offline
post #2 of 12 Old 02-02-2011, 11:12 AM
05TurboS2K
dime a dozen.
Decent setup for 33" locked or 35" open.
To upgrade:
D44 rear could probably survive 35" locked but I'd generally reccomend and upgrade to a super 44 kit and then a HP front 30.
05TurboS2K is offline
post #3 of 12 Old 02-02-2011, 11:13 AM
freeskier93
Yes, from the factory that's a good combo. You can run up to 35s without any mods to the axles. Of course with 35s other things should be done as well. Upgrade the axles to a super 44 or HPD30 and you will probably be set for life.
Really the only next step for axles would be ford 9 or d60s, which are some serious axles.
freeskier93 is online now
post #4 of 12 Old 02-02-2011, 11:16 AM Thread Starter
Logant
I know the 44 is what people want basically but how is the 30? DD with trails every now and then nothing major.. 2.5 inch RC lift
Logant is offline
post #5 of 12 Old 02-02-2011, 11:18 AM
freeskier93
Because the front axle doesn't see as much abuse the D30 is actually a pretty good axle.
For about 600 bucks you can upgrade it to an HPD30 which I believe makes it 20% or so stronger.
post #6 of 12 Old 02-02-2011, 11:39 AM Thread Starter
Logant
What would the stock gearing be?
Logant is offline
post #7 of 12 Old 02-02-2011, 11:47 AM
BlakJeep
stock gearing for the HPD30 found in XJ's are the following ratios, this can all be searched however, this is a very common topic, but I've asked questions before that could have been searched so here ya go:
3.07 - used with 4.0L engine / manual transmission
3.31 - only available on older (pre87?) 2 door XJs with "Fuel Economy" package
3.55 - used with 4.0L engine / automatic transmission
3.73 - found in some XJs with the towing package
4.10 - used with 2.5L engine usually, and older XJs with the "Off-Highway Vehicle" package.
4.56 - rare but can be found on some older (~ 89 ~) models with 2.5L engine and auto transmission
EDIT! sorry you have a 1997 so this may not be true *the gearing in TJs with the D30/D44 combo is most likely 3.73 if thats what you were asking also*
http://www.jeepforum.com/forum/f9/st...1/#post4118404
BlakJeep is offline
post #8 of 12 Old 02-02-2011, 11:48 AM
freeskier93
Based on year it could be 3.07, 3.55, or 4.10/4.11. Because it a D44 I would lean more towards the 4.10/4.11. I'm actually not sure because the the D44 in the 1997 sport was a factory option and is pretty rare.
Here are some great links you should read:
http://www.jeepforum.com/forum/f9/tj...9-11-a-615132/
http://www.jeepforum.com/forum/f9/tj...embers-722109/
The first link it gives you information about stock ratios, then at the bottom there is a link that will tell you how to determine your ratios for sure.
post #9 of 12 Old 02-02-2011, 12:03 PM
BlakJeep
I believe its only the rubi d44 that has 4.10/4.11, but yes definately read, helps out a lot down the road. Gears are often changed so unless your the original owner you may want to check the "for sure" way to tell your gear ratio as freeskier said
BlakJeep is offline
post #10 of 12 Old 02-02-2011, 12:36 PM
freeskier93
Yeah its kinda confusing, because based on year those are the ratios they would be. And 1997 the Rubi wasn't created yet and the D44 was a pretty rare axle because it was factory option.
OP, there should be a tag on the differential that gives the gear ration. If it's missing or unreadable there are a couple other methods outlined int the FAQ. Here's the direct link to figuring out your axle ratio:
http://www.jeepforum.com/forum/f9/fa...-ratio-615380/
There are a couple mathematical ways to do it.
Now I'm really curious to find out what ratio it is.
post #11 of 12 Old 02-02-2011, 02:12 PM
Apex
Recon death squad
Apex's Avatar
D44/HP30 combo locked on 35" tires will survive just fine.
For added security add in chromos on both ends and go wheel.
I wheel on 35" tires on a stock/locked HP30 and a Super35 kit with ARB...I have yet to break anything.
My buddy wheels on a stock/locked D30 and stock/locked D44 on 35" tires with much success.
I can't make a guess as to your stock gearing. BUT you can jack up the front axle off the ground and count revolutions of the driveshaft while making a complete revolution of the tire.
Apex is offline
post #12 of 12 Old 02-02-2011, 03:12 PM Thread Starter
Logant
alright thanks guys! i dont know if i will go to 33s just because of the power issuue.. i just dont wanna lose my top end power going down the highway
Logant is offline
axle , dana 30 , dana 44
Superior Axle's new axle Super Truss kit installed, beef up your axle for only $399 Jerry Bransford TJ Wrangler Technical Forum 164 01-09-2015 12:14 PM
Should the Front Axle & Rear Axle be off centered to the passanger side by .5"? Lemmiwinks TJ Wrangler Technical Forum 3 07-07-2009 10:27 AM
Superior Axle & Gear EVOLUTION SERIES Front Axle Tube Seals 95wrangler4life YJ Wrangler Technical Forum 3 02-17-2009 03:00 PM
What is the difference/benefit of a high pinion axle compared to a regular axle? bhicks TJ Wrangler Technical Forum 7 09-10-2008 04:32 PM
