Axle or gearing upgrades important? - Page 2 - JeepForum.com
post #16 of 20 Old 07-28-2010, 11:25 AM
roundlitefan
roundlitefan's Avatar
You asked where it should be on your priority list. If you have 3.73 and the 5 speed as stated, then IMO the gearing change is not a priority at all. It is perfectly adequate to get you where you need to go. Where it comes into play is your enjoyment while driving the Jeep.
If you feel you can still have fun driving your Jeep with the new tires, then don't worry about it, you won't hurt anything on your Jeep. I personally drove my 2000 TJ with 4.0 and 5 speed on 3.73's for years, and the loss of 5th gear on hills didn't really bother me.
I now have a 2005 w/ 4.0 and 6 speed, and I am geared at 4.56, which is a much, much better experience, but again, the older Jeep was not unbearable either!
roundlitefan is offline
post #17 of 20 Old 07-28-2010, 08:16 PM Thread Starter
heethern
Thanks for all the info and help finding out what equipment I have. I did, by the way, fill in my profile some more. I guess it's a plus that I have the D44 in the rear?
heethern is offline
post #18 of 20 Old 07-29-2010, 01:08 AM
MO2500
Absolutely Depending on how seriously you want to get into offroading with your jeep, it is a much stronger base axle to build from than the D35 and will hold up well to your new 33's
Instagram: @omsmike
MO2500 is offline
post #19 of 20 Old 08-09-2010, 07:53 PM
onewheel
i just got my tj and my heavy *** 32's (just temp) kill me with the 3.07 gears!!!
mine isnt a DD and is going way up very soon, so i just assume but the large gear in now to help.
my build sheet doesnt say an exact type, but it does say 175mm anti-slip diff with a 5-spd.
44 right??
and i have to get a low ratio carrier with a 4.56 or 4.88 gear correct?
onewheel is offline
post #20 of 20 Old 08-13-2010, 07:44 AM
GETTEMTJ
This will help. Search this (Stock TJ Specifications) it has everything you need to fill in your profile! If the Jeep was bought used be sure the previous owner didn't upgrade nothing.. Just my .02
GETTEMTJ is offline
axle , gear , upgrade
Axle upgrades Mont TJ Wrangler Technical Forum 7 01-24-2010 08:24 PM
Everything I need for axle upgrades? justin_76 TJ Wrangler Technical Forum 1 06-28-2009 05:16 PM
Axle upgrades DOHCRT YJ Wrangler Technical Forum 4 03-11-2008 07:57 AM
axle upgrades desertsport TJ Wrangler Technical Forum 6 08-07-2004 01:55 PM
