axle/gear upgrade advice... - JeepForum.com
post #1 of 3 Old 11-08-2009, 10:20 PM Thread Starter
gunnerharley
Hey guys/gals,
need some help. I have a 98TJ sport with d30/35 axles with 3.07's. I know I need to upgrade the gears or axles but don't know what I'm going to get myself into. I've been browsing the classifieds/ebay/craigslist looking for rubicon axles and such but haven't found anything yet.
Can anyone direct me to a thread/post of what I'm going to need to do the swap to 44's? and what else I will need to buy in regard to parts...
Thanks in advance...
Gunner
gunnerharley is offline
post #2 of 3 Old 11-08-2009, 10:29 PM
MikeBK
http://www.jeepforum.com/forum/f9/ru...r-pump-262686/
Heres on thread on the swap, see if you can get the transfer case too.
Consider Obama the lesson many in this country need to learn, the rest of us just have to pay for it!
MikeBK is offline
post #3 of 3 Old 11-08-2009, 11:46 PM
Max-Q
1983 CJ7
I wouldn't be so quick to dump the axles you already have. Have you looked into chromoly D30 axles and a S35 kit? You can find them easier than D44 axles and it will be cheaper and easier in the end and you will have axles that should be strong enough for almost anything you encounter.
1997 Jeep TJ
1983 Jeep CJ7
2011 JK Unlimited Rubicon
Max-Q is offline
Leaking Axle seal on the front. Should I upgrade the axle to a dana 44? MWguy101 YJ Wrangler Technical Forum 21 03-01-2012 12:08 PM
LJ axle upgrade and re-gear questions gcally TJ Wrangler Technical Forum 19 01-28-2009 07:02 PM
Gear/Axle advice please MillerTimeTJ TJ Wrangler Technical Forum 26 08-03-2007 07:23 PM
Grr...Frustration on Gear/Axle build sheet, jeep guru advice needed tmfrench TJ Wrangler Technical Forum 14 04-28-2007 08:59 AM
Axle/Gear Upgrade Options dpoelstra TJ Wrangler Technical Forum 14 08-11-2006 11:15 AM
