Axle conversion - JeepForum.com
post #1 of 10 Old 01-18-2011, 06:12 PM Thread Starter
skullyboy
Axle conversion
Opinions needed.
Let me start by listing what i have now. I have a 97 TJ sport. A Dana 44 rear axle with 4:10 gears. It is an open diff. It has the original drum brakes and I run 32" BFG Mud Terrain tires. I blew out my spider gears when i had chains on in the deep snow.
I picked up a Jk Rubicon rear Dana 44 axle with 5:13 gearing, the factory electronic locker and No Brakes for $700.
Should I: Buy the brackets, brakes, wheel conversion spacers and new drive shaft and pay a guy to weld on the brackets (im not that good of a welder), and change the gears in my front axle. and put in the JK axle?
or
Buy a locker or limited slip, have it installed and keep my current set up and sell the axle?
Also is there anything I havn't thought of yet??
skullyboy is offline
post #2 of 10 Old 01-18-2011, 06:32 PM
Shadowline
I believe the JK axle is wider... you might be further along to sell the JK axle and just fix your stock Dana 44...
2003 TJ 4.0 5-speed 31inch Goodyear Authority's, 2inch Rubicon Express Springs, Hella Vision Plus H/L's, IPF upgraded H/L wiring harness. JCR Offroad Stage 2 Frt Bumper with CocaCola Bottle opener, Smittybuilt XCR8 Winch, Rampage Bowless top.
Shadowline is online now
post #3 of 10 Old 01-18-2011, 07:25 PM
never monday
fix your 44.
never monday is offline
post #4 of 10 Old 01-18-2011, 07:38 PM
willis36
willis36's Avatar
bolt pattern is also different on the jk axle so you would have to deal with that
as well.
willis36 is offline
post #5 of 10 Old 01-18-2011, 07:43 PM
basssolow5
sell me the stock 44 and buy a jk axle for up front
colorado jeep club member #730
stimulating the economy one part at a time!
basssolow5 is offline
post #6 of 10 Old 01-18-2011, 08:26 PM
cj847
Just replace your spider gears with a lockrite. $300 and a couple of hours and your done.
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline
post #7 of 10 Old 01-18-2011, 08:34 PM
thirdeye
x2 fix the current 44
2004 4.0L I6 TJ BUILD:
1997 2.4L I4 TJ BUILD:
http://www.jeepforum.com/forum/f22/thirdeyes-second-tj-1816002/
thirdeye is offline
post #8 of 10 Old 02-15-2011, 04:41 PM Thread Starter
skullyboy
Thanks for the input. I think the majority is right. I would love to do this conversion, but since I have the 44 with 4.10 gears already it just seems easier to drop in a locker and go with what i have.
Anyone need a JK axle?
post #9 of 10 Old 02-15-2011, 04:43 PM
BriansCJ
1994 XJ Cherokee
I would find a JK front D44 to match it. Then put them both in and run JK wheels.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #10 of 10 Old 04-02-2011, 01:04 PM Thread Starter
skullyboy
Thanks for your input all. I decided to go ahead and sell the JK axle and have mine fixed. I took it into a local shop here in Colorado and am having an OX locker installed. Was a bit more expensive ($2100)than I thought it would be so I hope it is worth it.
axle choice , brakes , dana 44 , gear ratio recommendation , lockers
How-To: TJ Axle Shaft Conversion H3RTCH YJ Wrangler Technical Forum 117 06-24-2017 02:37 PM
TJ axle shaft conversion in YJ YJ_Aaron YJ Wrangler Technical Forum 28 05-26-2011 11:50 AM
88 YJ to TJ axle conversion demo44 YJ Wrangler Technical Forum 11 07-18-2009 12:33 PM
Axle conversion eclipse27 TJ Wrangler Technical Forum 7 10-23-2007 06:31 PM
Over Axle Conversion 03WrnglerSahara YJ Wrangler Technical Forum 13 03-03-2007 06:21 PM
