Axle bulid question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Axle bulid question
ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Nitro Gear Packages Now Available at Rockridge 4wdMarch Madness LOCKER SALE + FREE SHIPPING + $30-$50 REBATE
Unread 04-17-2015, 10:43 AM   #1
redneckjesus97
Axle bulid question
So I am looking at building axles front and rear for my 2002 tj, so which is better Dana 44 or Dana 60, the ford 8.8 was ruled out, and then which ever axle I do get I will be install new gears and a locker so which locker is the best idea and most reliable? Thanks in advanced guys
redneckjesus97 is offline   Reply With Quote Quick reply to this message
Unread 04-17-2015, 10:57 AM   #2
Ironhead
depends how big you want to go. if you want 35's, the d44. if you want 40-42, the d60
the d60 is a bigger diff, so with 35's it'll be hanging pretty low
ARB for the win
Ironhead is online now   Reply With Quote Quick reply to this message
Unread 04-17-2015, 11:00 AM   #3
JBTJ
Anything over 35's on a TJ just doesn't look good, IMO.
JBTJ is offline   Reply With Quote Quick reply to this message
Unread 04-17-2015, 11:01 AM   #4
rikkards
rikkards's Avatar
As mentioned above, need to know your tire size you are going to. So why not the 8.8?
X2 on the ARB
Machete don't tweet
- Machete
rikkards is offline   Reply With Quote Quick reply to this message
Unread 04-17-2015, 11:03 AM   #5
Ironhead
oem axle width and location, i agree.
Unread 04-17-2015, 01:44 PM   #6
redneckjesus97
I'll be running 35's and I just have see a lot more 8.8's break over the Dana 44/60 while locked, with the arb do you break lines very often? That's why I though either an ox locker, or electronic locker because you don't have an air line?
Unread 04-17-2015, 07:24 PM   #7
rikkards
rikkards's Avatar
Running 8.8 and ARB and haven't broken but A: I only ran it a couple times last year and B: I also did the Yukon Ultimate 88 (Super 88 knockoff but Superior had gone under so I had no choice) so running chromos and c-clip eliminator.
I can't really see it being any worse than a 44 for strength especially for 35's. The biggest disadvantage for 8.8 is the size of the pumpkin and I see it being a detractor with 33's but not as much with 35's.
For the ARB, as long as you run your lines with your brake lines you should be fine. Every one who I have heard breaking an air line is because they didn't run it right and it got snagged (and that is only a couple of people).
Machete don't tweet
- Machete
Unread 04-17-2015, 07:26 PM   #8
redneckjesus97
Originally Posted by rikkards
Running 8.8 and ARB and haven't broken but I can't really see it being any worse than a 44 for strength. The biggest disadvantage for 8.8 is the size of the pumpkin and I see it being a detractor with 33's but not as much with 35's. For the ARB, as long as you run your lines with your brake lines you should be fine. Every one who I have heard breaking an air line is because they didn't run it right and it got snagged (and that is only a couple of people).
Ok that's good to know then because that'll help my decision on lockers
Unread 04-17-2015, 08:12 PM   #9
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
I agree with avoiding building an 8.8 for the front axle. But it is a stronger axle than a TJ Dana 44, stock to stock.
What kind of brakes will you be using?
Mail crawling.
MisfitSeven is offline   Reply With Quote Quick reply to this message
Unread 04-17-2015, 08:20 PM   #10
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 04-17-2015, 08:30 PM   #11
MisfitSeven
MAiL Crawler.
Originally Posted by Knuckelhead
Ya, I guess it is possible. But it sounds like that would be too much fab work for the OP.
Mail crawling.
Unread 04-17-2015, 08:32 PM   #12
JeeperDrew78
I think the only cons to the 8.8 is that it's narrower than the 44 and the pumpkin is bigger (might contact the gas tank, mine clears barely) and the c clip. As far as breaking it though I think if you were in a situation where you broke the 8.8 you probably would have broke the 44. Agreed on the 60's being overkill for 35 inch tires.
JeeperDrew78 is offline   Reply With Quote Quick reply to this message
Unread 04-17-2015, 11:11 PM   #13
Knuckelhead
AFSOC Retired
And the ground clearance is less...
Unread 04-17-2015, 11:24 PM   #14
Greg_Volkman
Originally Posted by Knuckelhead View Post
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon
Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci
Greg_Volkman is offline   Reply With Quote Quick reply to this message
Unread Today, 04:51 AM   #15
rikkards
rikkards's Avatar
I don't look at the cclip as being a negative especially on 35's (same with the ground clearance).
Also doing the cclip eliminator you get rid of two of your cons (the width and the cclip). I don't recall what the clearance is though for the 60 vs the 8.8
Machete don't tweet
- Machete
