Quantcast Axle brackets ane axle width - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Axle brackets ane axle width
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 05-10-2005, 07:22 PM   #1
Dave Mathews
Axle brackets and axle width
My father recently acquired a dodge ramcharger that has a dana 44 front and a 9 1/4 rear. I want to narrow these axle's to fit my jeep (what is the width) and would need to know where I can order the correct brackets to weld on the new axle's. Any help or ideas would be appreciated. Thanx
2004, Wrangler, X, I6, Soft Top, 32's, black steel rims 3 1/2" bs, 2" BB, 4 KC Daylighters, light bar, bushwacker 6" flares,Sienna Pearl Coat.
A trip out yonder,
A voyage for the soul,
A platform for a journey,
A jeep 4X4 life...
Dave Mathews is offline   Reply With Quote
Old 05-10-2005, 07:37 PM   #2
joeyt17
1981 CJ7
i know you can find a bracket kit made by either rubicon express and MORE. i think the prices are about the same for the two manufactures (approx $250)
they are not a pefect fit to your axle tubes most likely so a little grinding will be necessary before welding them up.
joeyt17 is offline   Reply With Quote
Old 05-10-2005, 07:44 PM   #3
Dave Mathews
Is that for the front and rear?
A trip out yonder,
A jeep 4X4 life...
Old 05-10-2005, 07:45 PM   #4
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
That price is for the rear only. They probably have them for the front too, contact Rubicon Express or M.O.R.E. to see what they have.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 05-10-2005, 08:10 PM   #5
TJ=MT Pockets
just a silly question, but isn't a ramcharger a pass. side drop front axle?
Y2K 4L 5spd TJ Sport--4.5" RE SF all adj. arms--1" BL--1" MML--33"bias swampers(soon to be 36" swamper sx's on rockcity diy beadlocks)--D44 4.88's arb w/alloy usa shafts--HPD30 4.88's locrite w/warn alloy inners--warn small hub kit--longfield hd u-joints--currie steering--currie anti-rock--tera low--A-Z Fab cage--and a bunch of skids
TJ=MT Pockets is offline   Reply With Quote
Old 05-10-2005, 08:32 PM   #6
MMagnumPI9
ever think about running them full width?
MMagnumPI9 is offline   Reply With Quote
Old 05-10-2005, 08:40 PM   #7
wakeboarder 21
no, dodge has driver drop
98 TJ
5spd,4banger
RE 3.5 __ 1" BL__RE front adj. trac bar__Currie Anti Rock sway bar__33 BFG M/T with some black steelies__K&N Filter__CB___ Durango 4x4 Front Bumper
building for 37s
[URL=http://orw.truckmoxie.com/mygallery.ten?id=4573]***PICS***[/URL]
wakeboarder 21 is offline   Reply With Quote
Old 05-10-2005, 08:41 PM   #8
wakeboarder 21
i would run them full width then if you need to be street legal get rims with less back spacing
98 TJ
5spd,4banger
building for 37s
Old 05-10-2005, 08:53 PM   #9
Dave Mathews
The front 44 measure's out at 65", my stock 30 measures out at 55". 5" a side is way too much to make up in just backspacing. It would be easy to put them on how they are however, I can cut the slack of the ends and press new ends on. I really wanted to know stock axle widths for the 35 rear and 30 front (I took a generic measurment). I also need to figure out what size ready made axle shaft will fit if I narrow the new diffs. It is a lot of reaserch unless one of you know
A trip out yonder,
A jeep 4X4 life...
Old 05-10-2005, 10:21 PM   #10
1BLKJP
TJ axles are 59.5" WMS to WMS. But you might be better off to run them at something like 60 or 61 inches. If you want to put together a project of this size then you might as well help yourself out with some extra track width.
And yes RE does sell both front and rear bracket kits and they will probably run you about 600 for all of them.
Have you done any checking locker and gear options on that 9.25? I know that is not an all too common axle that gets built. As far as shafts go I don't know if you will find anyone that has TJ stock length shafts for that rear axle either. But I bet Dynatrac or Superior will make you custom axle shafts for your application.
1BLKJP is offline   Reply With Quote
Old 05-11-2005, 08:09 AM   #11
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Rusty's also makes TJ brackets.
Last I remember, they are a little cheaper than most others (around $225). He can also make them specifically for the axle, so you shouldn't have to grind them to fit.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 05-18-2005, 09:38 PM   #12
TJ=MT Pockets
well, not to beat a dead horse, but my friend came over tonight and he has an old ramcharger and it is pass. side drop. i dont know what year it is, i forgot to ask, but it was a pass. side drop front axle.
Glock Forum
