ax15 to nv3550 - JeepForum.com
post #1 of 4 Old 02-24-2012, 12:47 PM Thread Starter
pickleman
ax15 to nv3550
i have a 1999 tj and it has an ax15 in it and 2nd and reverse are going out and i got my tax money back so i am ready to either put a new ax15 in it or swap an nv3550 in it wich is what i want to try to do i have heard that it is possible but since i am going to be doing this i would rather know for sure before i ripp my tranny and the nv3550 not work.
i know that i will need an external slave cyllinder
i am going to be putting in a beefier clutch at the same time i need a good suggestion on as to wich brand and clutch will work good with 33 inch tires,
if i am missing anything please let me know this is my daily driver
my 99tj build http://www.jeepforum.com/forum/f22/bad-company-tj-1291247/
pickleman is offline
post #2 of 4 Old 02-24-2012, 02:18 PM
Jeepsr4me
Stay with what you got. Ax15s are pretty easy to find and are IMO just as good as the other one.
Jeepsr4me is offline
post #3 of 4 Old 02-24-2012, 03:08 PM
LongTooth
X2 on this. Rebuild it and go with a sach's clutch, good to go for a long time.
JEEP, Because the road to paradise is not paved.
Originally Posted by biffgnar View Post
Biggest weak spot for many TJs is the loose nut behind the wheel.
LongTooth is offline
post #4 of 4 Old 02-24-2012, 06:37 PM
cfmiller58
x3. no gains by swapping in a nv3550. the standard luk clutch is what you want and can be readily found for around 100 bucks on ebay or at Pep Boys
Black Jeep Society
cfmiller58 is offline
ax15 , nv3550 , tranny swap
NV3550 vs AX15 TeeJay00 TJ Wrangler Technical Forum 23 02-20-2011 11:16 AM
AX15 vs NV3550 czjeeper YJ Wrangler Technical Forum 20 05-25-2010 07:59 AM
ANYONE WHO HAS DONE A AX15 to NV3550 SWAP VABYJ YJ Wrangler Technical Forum 7 10-22-2007 08:54 AM
Ax15 Or Nv3550 SB99TJ TJ Wrangler Technical Forum 2 12-13-2005 02:50 PM
NV3550 or the AX15? glennv TJ Wrangler Technical Forum 5 02-13-2003 01:21 PM
