Ax15 bellhouse knocking when cold? - JeepForum.com
post #1 of 1 Old 07-22-2010, 07:55 PM Thread Starter
ytowntj
Posted this in the drivetrain section too but no bites yet so...
Like the title says
I have a 1999 Tj with a 4.0/Ax15 with 160 K on it. There is a distinctive knock coming from the bell housing that is worse when its cold and goes away after several minutes of driving. It varies with engine speed and stays constant with rpm whether clutch is in or out, or trans is in or out of gear.
Note... this is definitely coming from the bell housing not the oil pan. It sounds like a rod bearing and I thought it was one. I was about to pull the pan off today when I listened to it again and determined it is definitely not from the engine.
After it is driven for a few minutes the knock goes away completely and it runs like a champ. Any suggestions as to what this might be? Thanks!
ytowntj is online now Report Post
ytowntj is offline
ax15 , knocking , cold , bellhousing , help
Ax15 bellhouse knocking when cold? ytowntj YJ Wrangler Technical Forum 1 07-22-2010 07:53 PM
08 JK knocking on cold start? Millermagic JK Wrangler Technical Forum 49 05-19-2010 06:42 PM
Knocking from bellhouse philliesfan5 TJ Wrangler Technical Forum 3 03-28-2009 03:47 PM
4.0 knocking when cold masterwacker TJ Wrangler Technical Forum 2 05-07-2007 03:39 AM
Knocking Sound when Cold ssikrup TJ Wrangler Technical Forum 5 11-19-2004 11:37 PM
