AX-15 transmission problems - JeepForum.com
post #1 of 8 Old 07-07-2010, 10:20 AM Thread Starter
Anthen27
I have owned my 5 speed (AX-15) 6cyl 99' TJ since new, I use it to commute to Manhattan every day (about 26 miles each way) she has 141,000 miles on it now, anyway the other day coming home from work the tranny started to give me trouble shifting (slight grind downshifting from 4 to 3) and them got progressivly worse gringing between gears as I drove home. By the time I got off the parkway at my exit when I would decelerate in 5th I would get a nasty vibration that felt like my driveshaft u jonts were bad. I thought maybe the fluid is low? I went to the autoparts store and picked up 3 quarts of penzoil 75/90 synchromesh and drained the old fluid (slightly low fluid level, no water or metal chunks) and refilled it, same exact problem of course, I get under the jeep no leaks, u joints look good, mounts seem intact, clutch pedal has not moved engagement position (clutch master/slave seem fine) so my guess is the AX-15 tranny has worn synchros and bearings and needs to be rebuilt. So local tranny shops quoted me about $2000-$2500 for replacing my tranny with a rebuilt AX-15 unit and new aftermarket clutch. Or another option is I go to autozone/advance auto and buy a rebuilt AX-15 unit for $1100 after tax and my old tranny core, buy a LUK clutch for another $150 or so and spend a weekend on my back in the driveway. I was leaning tword doing the job myself, a few years back I did a AX-5/231 from a 99' TJ wrangler into my buddies 93' YJ wrangler due to the 5th gear circlip problem during the dead of winter in the driveway, so I can do the job but it would be hard for me on my back in the driveway, I go on craigslist/ebay to look for used/rebuilt AX-15 trannies and find a guy Tim in Pennsylvania, he has a buisness called JEEP TRANSMISSION REPAIR SERVICE - rebuilt transmissions with quality OEM Mopar parts and after speaking to him he can rebuild my tranny with OEM parts for a very reasonable price, so I bring my jeep to him, nursed it in 4th gear on RT80 (210 miles away) he quoted me $250 for AX-15 basic rebuild kit which includes scnchros/bearings, gaskets and seals (mopar parts) and $250 labor to rebuild the tranny, $350 to remove re-install the tranny, $150 for a new LUK cutch kit and $50 for oils/shop supplies so for $1050 I was getting a full rebuild and new clutch on my AX-15 tranny which seemed very reasoble to me. That was last Saturday when I dropped it off, so Tuesday I get a call from Tim, turns out after a test drive I have some grinding in the drivetrain that is NOT my tranny, after pulling my rear end apart (D-35) it seems I need new spider gears in the rear and of course bearings and seals, he first thought it was axle bearings (common problem) but the spider gears are totally shot. so I tell him to go ahead and replace the spider gears and rebuild the D-35 rear end, then he calls me on Wednesday that my tranny also needs 5th gear and the mating cluster gear and some other hard parts that were worn beyond limits and that would be an additional cost, Thursday I get a call that my 231 tranfer case needs a chain and new seals also, So now I am up to $1765 plus oils and supplies......Do you guys think this sounds right? Has anyone used Tim in PA from Jeeptransmissions.com? $1765 still seems reasonable to rebuild the D-35 and the AX-15 with OEM parts, cut flywheel and LUK clutch kit, chain and seals for the 231, grind and paint rust under tranny skidplate etc.......any opinions?.........
Anthen27 is offline
post #2 of 8 Old 07-07-2010, 11:24 AM
TheBoogieman
Made in the USA
TheBoogieman's Avatar
I'd go ahead and do it since you probably owe him quite a bit for all the tearing down to check it out.
TheBoogieman is offline
post #3 of 8 Old 07-07-2010, 03:40 PM Thread Starter
Anthen27
i guess i will have him do the job, but i wanted to know if the prices sound right and if anyone had and experience with tim from jeeptransmisions?
Anthen27 is offline
post #4 of 8 Old 06-07-2012, 09:46 AM
JohnL48
1967 CJ5
Did you ever find what the issue was with the transmission? my 98 tj is doing the exact same thing with downshifting from 4th to 3rd and 5th making a noise.
my trans. is actually a rebuilt trans I purchased from Jeep Transmissions you are referring to. This guy is a crook. I got the trans from him, put it in and it popped out of third gear. Took the trans out and sent it back to him at my expense, put it in and the trans. grinded slightly going into 2nd. At this point $ 750.00 for the trans. $ 150.00 for shipping both ways which he refused to pay for and taking the tranny out twice i just gave up and lived with it. 2 yrs later i'm having big problems with it.
I know this is an old post but anyone reading this stay away from http://www.jeeptransmissions.com/
He's a thief
JohnL48 is offline
post #5 of 8 Old 11-05-2014, 06:16 PM
rk4n3
1999 YJ Wrangler
Tim at JeepTransmissions.com
I just wanted to provide some info about this for any shoppers out there.
I had Tim rebuild a transmission for me, and it didn't work out very well.
I have to say that Tim was polite and easy to work with, and we worked on this project for almost two years. I shipped the transmission and transfer case back and forth more than once, and Tim did alot of free labor on it, in an effort to deliver what I had purchased, but in the end the transmission never did work right and I had to have someone else do the job.
What I found out from the shop that re-performed the work was that along with the kit used in Tim's rebuild, there were also some older/warn parts used, and the kit didn't match up very well, and certainly wasn't installed very well. There's no way to tell for sure, but its possible that the transmission *could* have worked if it had been dissassembled and reassembled well immediately upon receipt (before driving it), but as it was, driving with it caused some problems that required another rebuild.
I ended up paying around $1800 to Tim, and then turning around and paying $2800 to the other shop to get the job done. That shop, as well as another shop (where I got a second opinion), both quoted around $2800 to do the job from the start, so go figure.
rk4n3 is offline
post #6 of 8 Old 11-06-2014, 03:36 PM
doublins
Originally Posted by rk4n3
I just wanted to provide some info about this for any shoppers out there. I had Tim rebuild a transmission for me, and it didn't work out very well. I have to say that Tim was polite and easy to work with, and we worked on this project for almost two years. I shipped the transmission and transfer case back and forth more than once, and Tim did alot of free labor on it, in an effort to deliver what I had purchased, but in the end the transmission never did work right and I had to have someone else do the job. What I found out from the shop that re-performed the work was that along with the kit used in Tim's rebuild, there were also some older/warn parts used, and the kit didn't match up very well, and certainly wasn't installed very well. There's no way to tell for sure, but its possible that the transmission *could* have worked if it had been dissassembled and reassembled well immediately upon receipt (before driving it), but as it was, driving with it caused some problems that required another rebuild. I ended up paying around $1800 to Tim, and then turning around and paying $2800 to the other shop to get the job done. That shop, as well as another shop (where I got a second opinion), both quoted around $2800 to do the job from the start, so go figure.
Holy crap!
I bought a rebuild kit and just rebuilt it myself in my garage 2 winters ago- took a week with waiting on some parts, first trans I ever rebuilt, it's been perfect behind my V8. How on earth did this Tim dude screw up? The AX is easy to rebuild
98 TJ Street Sleeper- 408ci Stroked Magnum V8
My Magnum V8 Build Thread:
doublins is offline
post #7 of 8 Old 11-07-2014, 10:52 AM
rk4n3
1999 YJ Wrangler
Originally Posted by doublins View Post
Holy crap!
That's a great question - unfortunately, I'm not any kind of mechanic, so I have no idea how to answer that question, other than to relay what my usual auto-shop guy ended up telling me. Bottom line, I didn't get what I paid for (by a REALLY long shot). My usual shop guy even tried to help me convince Tim to refund my money, but no dice - Tim eventually stopped answering his phone and email.
rk4n3 is offline
post #8 of 8 Old 11-07-2014, 04:48 PM
JohnL48
1967 CJ5
Mine started popping out of 3rd again. Tim use's old parts to assemble "rebuilt" transmissions. I'm just going to wait and get a brand new one from advanced adapters. I am sooo done with "rebuilts" And Tims a crook
JohnL48 is offline
grind , grinding , ax 15 , ax-15 , ax15 , tranny , transmission , problem , help , TJ
Transmission Problems ssfitz YJ Wrangler Technical Forum 5 09-11-2008 12:17 PM
transmission problems 03_X TJ Wrangler Technical Forum 0 06-05-2008 04:30 PM
Help! Transmission problems! ismith75 TJ Wrangler Technical Forum 3 05-05-2008 01:25 PM
Transmission Problems FutureFire YJ Wrangler Technical Forum 6 06-18-2007 07:34 PM
Transmission Problems DANDMAN TJ Wrangler Technical Forum 6 06-13-2006 07:35 AM
