AX-15 4th Gear Only - JeepForum.com
post #1 of 4 Old 07-12-2010, 07:59 PM Thread Starter
pointblanke
AX-15 4th Gear Only
I was driving home from work last night when my transmission stopped working. I was on the interstated doing about 70 in 5th when power stopped going to the wheels. No other problems were noted and everything was working fine up until then. The only gear that worked was 4th. I was able to nurse it home. I'm assuming I'll need some significant repairs, but wanted to see if there's anything to be looking for. Thanks!
"It's better to be dead and cool than alive and uncool" Harley Davidson and The Marlboro Man
pointblanke is offline
post #2 of 4 Old 07-12-2010, 10:16 PM
BlueFlame
BlueFlame's Avatar
Probably wore the teeth off the input gear. (4th is 1:1 straight through and uses no gears.)
Not uncommon when you run large tires with too tall gearing or have a habit of lugging the engine, especially with a work truck that tows a lot.
Andddddd.... I found this:
http://www.jeepforum.com/forum/f9/on...placed-821016/
BlueFlame is offline
post #3 of 4 Old 07-13-2010, 01:48 PM
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
I had this happen in my Mazda B4000 and it was a bad clutch. Doing about 70 with the cruise control on, the RPMs rev'd high. I put the clutch in to change gears and it went to the floor with no resistance. Were you able to use your clutch to change gears from 5th to 4th? Dont know if its the same issue, but it sounds similar.
-Dave
AustinCJer is offline
post #4 of 4 Old 07-13-2010, 04:27 PM
BlueFlame
BlueFlame's Avatar
If he could nurse it home with only 4th gear, clutch has to be good...
tranny , transmission , ax15 , ax-15 , broke , broken
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 07:58 PM
Opinion Wanted On Gear Pattern -- New Gear Setup Jim93YJ YJ Wrangler Technical Forum 9 01-16-2011 01:14 PM
Dana 44 rubicon rear limited slip gear oil, synthetic or regular gear oil what weight rutacon05 TJ Wrangler Technical Forum 6 09-16-2009 09:53 AM
New Gear Break In..When to Do Initial Gear Lube Change?? Jim93YJ YJ Wrangler Technical Forum 8 10-14-2008 08:59 PM
Spider Gear Missing a Tooth After Re-Gear Break-in Period beertinted TJ Wrangler Technical Forum 2 06-20-2007 02:34 PM
