aw4 swap cost? - JeepForum.com
post #1 of 35 Old 11-23-2012, 08:01 PM Thread Starter
billbanshee
aw4 swap cost?
anyone on here keep track of total cost involved? i hate shifting!!!!!!!!!!!!
98 tj sahara
re4.5sf,bfg 33 12.50mt d30arb/d44 detroit 456 gears
bulletproof bumpers/tomken skids/tor roll cage
warn 9000i
billbanshee is offline
post #2 of 35 Old 11-24-2012, 09:27 PM
Rubiman805
The swap will run you about $800.
Iím currently working on getting all the parts to do a swap on my 04 TJ.
Iím having a hard time finding the 98-01 AW4 transmission.
I already have everything else. Good luck with your swap!!!
Here is a link you can check out.
http://www.stu-offroad.com/engine/aw-4/aw-4-1.htm
Rubiman805 is offline
post #3 of 35 Old 11-25-2012, 04:19 AM
rhovater
I just did a swap in my TJ. I went from a 2.5L and AX5 to a 4.0 and AW4 out of a 2000 Cherokee sport. I spent more money on the engine part of the swap than the AW4. It was more time consuming than anything, making the harness and all. It was not that expensive for me. BUT I did not have to get different drive shafts. X2 on Stu's page.
rhovater is offline
post #4 of 35 Old 11-25-2012, 03:59 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You will have to find your own costs after you add them up.
2 driveshafts modified and balanced, scrounged from for sale sections, or purchased new.
All the little bits add up as well if you don't get them with the trans-
Flex plate bolts x 6
Flex plate
Shifter from a 32RH with cable and floor plate
Shift indicator
Trans mount of some kind
Wire and connectors for making the harness
Bolts to attach bellhousing to engine if they aren't ALL included.
Drill jig from someone if you don't have access to one to drill the back of the AW-4 to clock it for the TJ.
All of that is assuming that you get the torque converter, TCM, dipstick, NSS, and the black and gray plugs to make the harness with when you buy the trans.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #5 of 35 Old 11-25-2012, 04:13 PM
rhovater
I got some of my parts at the local salvage yard...tube filler, shifter and cable. (40 BUCKS) I used my manual shift boot in stead of the PRND21. My transfer case came with my tranny and engine so I got lucky there too. TCM off of Ebay for 25 and it came with the pig tail too. My dad is a welder so we were able to modify my skid plate to mount the AW4 to it. 8 qts of tranny fluid at 5.99 a pop..ouch. I did not use a cooler, just because I am not going trailing for a while but will be a mod later on. I just ran hoses through the radiator. Big thanks to MrBlaine for help with my ECU.
rhovater is offline
post #6 of 35 Old 11-25-2012, 04:41 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Before you get too comfy about not having a cooler, install a temp gauge. You'll have a cooler sooner than later if you have any hills.
I am Savvy
mrblaine is offline
post #7 of 35 Old 11-25-2012, 04:47 PM
maztj
is this a common swap? i would think a 700r4 would be better. i know the xj guys talk about the aw4 not haveing seperate 1st and 2nd. This is interesting me cause my tranny just went in my tj!!!!
maztj is offline
post #8 of 35 Old 11-25-2012, 06:16 PM
Border Dave
Got Sand?
Border Dave's Avatar
Yes, it is starting to become a more common swap.
The stall speed on the 700r4 isn't right for the 4.0 in the TJ.
On the AW4, if you put the shifter in "1-2", it will hold 1st gear until around 4500 rpms. There are a couple of aftermarket shifters for it that allow it to stay in 1st gear indefinitely, but they aren't needed.
Border Dave is offline
post #9 of 35 Old 11-25-2012, 07:00 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I know a few folks that did the 700R4 swap. They own more different stall speed torque converters than should be legal, the adapters are very expensive as in if you pay retail, more than enough will be spent to get all the parts in general for the AW-4 swap. They are also a bit snivelly over how hot they run.
I am Savvy
mrblaine is offline
post #10 of 35 Old 11-25-2012, 07:36 PM
rhovater
[QUOTE=mrblaine;14506085]Before you get too comfy about not having a cooler, install a temp gauge. You'll have a cooler sooner than later if you have any hills.[/QUOTE
Not too hilly here in NC. Id like to do the cooler set up that Stu did on his. I just need to save the cash. I have only had it on the road a week now. So far I like the set up. Of course I went from a 4 banger, but it shifts smooth.
rhovater is offline
post #11 of 35 Old 11-25-2012, 07:56 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
So what is the current state of the art on getting the AW4's lockup torque converter to lock/unlock automatically without the usual check engine light? I know many don't bother trying to make it work automatically and just wire a flip-switch so they can lock/unlock the AW4's torque converter but that's a PITA if the Jeep is also driven on the street much.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #12 of 35 Old 11-25-2012, 09:05 PM
rhovater
Here comes a wrench.....
MY 97/2000 TJ HYBRID
rhovater is offline
post #13 of 35 Old 11-25-2012, 09:18 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Nothing to it at all. No check engine light if you swap in a manual PCM and leave the stand-alone TCM that the AW-4 needs intact and interfaced correctly.
I am Savvy
mrblaine is offline
post #14 of 35 Old 11-25-2012, 09:34 PM
rhovater
I checked my codes a couple of times and I've been good. Except for o2 sensors...tranny has been good to go.
rhovater is offline
post #15 of 35 Old 11-25-2012, 10:12 PM
mike481
mike481's Avatar
I did a cooler and temp gauge when I did the swap. At the time I was living in South Dakota and the temp rarely got to 175 even in the black hills. Now that I'm back in southern California I see the temp difference and could not be happier I put in the temp gauge and cooler.
Mine works great and no CELs.
Chuck- A better dog than I could ever deserve
RIP 4-14-2012
mike481 is offline
