#1 | |
autozone lift kit
Im sure as anyone, budget boost lifts are the cheapest way to get a cheap lift, which im needing right now.
I have been reading, about 93 through 98 grand cherokee v8, their front coil springs drop right in a tj front, no mod needed. They are stiffer, which gives about 2" lift. I have 3 2" spacers pucks from collins bro a friend gave me, new in box, because he lost one. Are there any downsides to getting new GC springs from autozone, stock oem replacements, installing them in the front with 2" longer ranchos. Then installing new tj rear springs, with new shocks as well, and the pucks to achieve a 2" lift on a budget. Well under 200 bux spent for everything. What about pitman arm, rear track bar, and brake lines? My stock springs are too wore out to use the 3 spacers I have, not to mention collins bro spacer kit is on back order, so I cant order a 4th one.
#2 |
JF is my second home.
Here's some info on what you are talking about, I would go with the rear Crown Vic police springs, should be able to get them at a Junk yard pretty easily. Here is another option if you want another BB spacer.
Max 2003 Jeep Wrangler Rubicon 4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs. TJ Tech Boot Camp TJ Specs "Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track" |
#3 |
Director of Philosophy
Some people have vibration problems with only 2" of lift due to the increase in driveline angle and the fact that the rear pinion is no longer parallel to the transmission. Not saying you will, but if you do it can be fixed cheaply with a motor mount lift, transfer case/skid drop, or you can go the more expensive route and do SYE, double cardan DS, and adjustable uppers. Then again, you may not have vibes.
Joel Morris '89 Grand Wagoneer |
#4 |
To add 2" of lift with coil spacers is ok. All you need is spacers, brake lines maybe, and shocks. Any higher and you need drop pitman arm, different control arms, and other stuff to do it right.
ET48 1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs. 1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s. |
#5 |
Probably cheaper to just buy a new BB.
#6 |
i have 2" bb on mine..slight vibes so i installed some flat washers as a spacer on the tc and no more vibes, no extra parts needed.
my build thread: http://www.jeepforum.com/forum/f22/my-98-jeep-767893/ |
#7 |
no new longer pitman arm without a relocated track bar. Its best to leave steering stock, and beef up those chep tie rods
#8 |
forum supporter
http://www.roughcountry.com/jeep_tj_2.html Just a little more than you wanted to spend, but gets you all new coils,shocks, and a t-case drop. Plus jeepforum members get a 10 percent discount.
#9 |
Why would he need all that stuff, no need for a drop pitman arm they usually cause more problems that the are worth, and the stock control arms work fine up to 3.5" of lift. He will need new shocks, brake lines are also fine until you get to 4" of lift, most people can lift a jeep with out vibes to 2.5" after that usually a t-case drop or MML is required. When near 4" you will need a SYE and CV drive shaft.
#10 | |
Stock control arms at 3.5" of lift would ride rougher than a CJ. ![]() ![]()
#11 |
What ever you say I guess, you are a CJ owner and apparently know everything about TJs, most of you ride control comes with the type of shocks you buy, there are many TJs that run 3" springs on stock CA's with out problems. The RC 2.5" Coil spring lift uses stock CA's and rides much better than stock. You also seem to think you need drop pitman arm go read the threads about them on JF every body complains about them, even with 4" of lift many use the stock pitman arm just because they causes so many steering problems.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
